Guest BlueFireIce Posted September 5, 2007 Share Posted September 5, 2007 Ok, I would like to start by saying this is my first time making a how to so bear with me here. So if anything is missing or needs a better explanation PM or e-mail me and let me know. And if the photos are to small let me know, the originals are over 3mb each and thought it would be better to bring the size down. To start, I did NOT drain the coolant, but most of you will want to so you can get the water pump out of the way, I am use to cramped mechanic places so it did not bother me. First part is easy. Just remove the clutch and speedo. After that there are two (2) bolts holding on the sprocket cover. As photo says, only two (2) bolts that need to be taken off to remove the water pump, the others hold the two half's of the pump together. There are two (2) other bolts behind the water pump that hold the shift cover on. If you are taking the water pump off you just remove the hoses and pull off the pump. As photos says, tight, but can be done. Watch out for the part in the middle, it has little spring loaded parts in it and they can get lost very easy....Trust me. Remember how the last two parts go on and line up. Also, when putting everything back, make sure you slide it all the way back on. When taking the star off it will spin with the nut, just turn it (about one full turn) and it will stop, then remove the nut and the star will slide off. There is a little bump on the back, make sure you line it up with the new star. I had to put the cover and shaft back on at the same time since I did not take off the pump. This is why I said for most of you its a good idea to take it off as you need the shafts and arms lined up on this! I could "feel" when it was right, but you may not, you do this at your own risk. I do not accept any responsibility for anything you may mess up for break! I make no guarantee that this info is perfect! Quote Link to comment Share on other sites More sharing options...
Guest BlueFireIce Posted September 10, 2007 Share Posted September 10, 2007 Ok, I would like to start by saying this is my first time making a how to so bear with me here. So if anything is missing or needs a better explanation PM or e-mail me and let me know. And if the photos are to small let me know, the originals are over 3mb each and thought it would be better to bring the size down. To start, I did NOT drain the coolant, but most of you will want to so you can get the water pump out of the way, I am use to cramped mechanic places so it did not bother me. First part is easy. Just remove the clutch and speedo. After that there are two (2) bolts holding on the sprocket cover. As photo says, only two (2) bolts that need to be taken off to remove the water pump, the others hold the two half's of the pump together. There are two (2) other bolts behind the water pump that hold the shift cover on. If you are taking the water pump off you just remove the hoses and pull off the pump. As photos says, tight, but can be done. Watch out for the part in the middle, it has little spring loaded parts in it and they can get lost very easy....Trust me. Remember how the last two parts go on and line up. Also, when putting everything back, make sure you slide it all the way back on. When taking the star off it will spin with the nut, just turn it (about one full turn) and it will stop, then remove the nut and the star will slide off. There is a little bump on the back, make sure you line it up with the new star. I had to put the cover and shaft back on at the same time since I did not take off the pump. This is why I said for most of you its a good idea to take it off as you need the shafts and arms lined up on this! I could "feel" when it was right, but you may not, you do this at your own risk. I do not accept any responsibility for anything you may mess up or break! I make no guarantee that this info is perfect! Quote Link to comment Share on other sites More sharing options...
Forum CEO HispanicSlammer Posted December 21, 2008 Forum CEO Share Posted December 21, 2008 Ok, I would like to start by saying this is my first time making a how to so bear with me here. So if anything is missing or needs a better explanation PM or e-mail me and let me know. And if the photos are to small let me know, the originals are over 3mb each and thought it would be better to bring the size down. To start, I did NOT drain the coolant, but most of you will want to so you can get the water pump out of the way, I am use to cramped mechanic places so it did not bother me. First part is easy. Just remove the clutch and speedo. After that there are two (2) bolts holding on the sprocket cover. As photo says, only two (2) bolts that need to be taken off to remove the water pump, the others hold the two half's of the pump together. There are two (2) other bolts behind the water pump that hold the shift cover on. If you are taking the water pump off you just remove the hoses and pull off the pump. As photos says, tight, but can be done. Watch out for the part in the middle, it has little spring loaded parts in it and they can get lost very easy....Trust me. Remember how the last two parts go on and line up. Also, when putting everything back, make sure you slide it all the way back on. When taking the star off it will spin with the nut, just turn it (about one full turn) and it will stop, then remove the nut and the star will slide off. There is a little bump on the back, make sure you line it up with the new star. I had to put the cover and shaft back on at the same time since I did not take off the pump. This is why I said for most of you its a good idea to take it off as you need the shafts and arms lined up on this! I could "feel" when it was right, but you may not, you do this at your own risk. I do not accept any responsibility for anything you may mess up or break! I make no guarantee that this info is perfect! Quote Link to comment Share on other sites More sharing options...
ciprinakos Posted August 27, 2012 Share Posted August 27, 2012 For those of you who install a factory pro shift kit on a V-tec (2002-2010 / 6th generation VFR), first install the arm and spring and only after that put the star in position (a pesky job). Do it like this because the spring is quite strong and you risk to damage the thread on arm & spring bolt. After mounting the arm & spring, use a screwdriver to keep the arm's micro-bearing away from the star while mounting (if done right you can secure the screwdriver holding the arm by the foot peg during star's installation). You only need to drain the oil not the coolant. Good luck! Quote Link to comment Share on other sites More sharing options...
