Guest symchuk Posted September 28, 2009 Share Posted September 28, 2009 After reading everyone's comments, I order a fuzeblock and it just came in today. I took the seat off and discovered there really is not a lot of room. Has anyone installed the buzeblock on a 6th generation ABS bike? If so, can you send me some photos on where and how you installed it. Thanks. Link to comment Share on other sites More sharing options...
Lee 2002 Posted September 28, 2009 Share Posted September 28, 2009 I have one sitting on my tool chest right now. I will get it installed sometime this winter when there is snow on the ground. I'll post photos when I do. I have test-fit and plan on installing it behind the rear brake resevoir... it appearst to just barely fit there. Link to comment Share on other sites More sharing options...
Guest Posted September 29, 2009 Share Posted September 29, 2009 I have the fuse box that Tightwad sells with the VFRness installed by the rear brake reservoir. I put the relay right next to it - UNDER the center frame support... had just enough room to squeeze it under there. Link to comment Share on other sites More sharing options...
Guest Posted September 30, 2009 Share Posted September 30, 2009 I have one sitting on my tool chest right now. I will get it installed sometime this winter when there is snow on the ground. I'll post photos when I do.I have test-fit and plan on installing it behind the rear brake resevoir... it appearst to just barely fit there. I'm planning the same location, but i have not figure out how to secure it in place yet. Link to comment Share on other sites More sharing options...
Member Contributer solohvs Posted September 30, 2009 Member Contributer Share Posted September 30, 2009 I had a little more room to work with - NON ABS 2005. The space where the ABS plumbing would go gave me plenty of room and I used adhesive backed VELCRO and some neoprene foam to keep thing in place. I also made the wires long enough so the I could pull the unit out to work on it. NICE LITTLE BOX - it worked well. Alarm - GPS - Nasty Horn - Electric Vest - plenty of room! Brian IMG_1377.JPG IMG_1374.JPG Link to comment Share on other sites More sharing options...
Member Contributer dutchinterceptor Posted September 30, 2009 Member Contributer Share Posted September 30, 2009 I put one on my other VFR and really like the setup with the integrated relay. Mine's not an abs but here's the location after a tiny bit of cutting on the plastic. Link to comment Share on other sites More sharing options...
Member Contributer pm_wizard Posted September 30, 2009 Member Contributer Share Posted September 30, 2009 I squeezed it in under the seat across from the rolled up tool kit (left side of bike). It is awkward but it does fit. I had to relocate my flashlight and rolled up mechanics cloth! John Link to comment Share on other sites More sharing options...
Guest Posted October 2, 2009 Share Posted October 2, 2009 I put one on my other VFR and really like the setup with the integrated relay. Mine's not an abs but here's the location after a tiny bit of cutting on the plastic. I've tried that location, but it won't fit. I tried to use velcrove but it added to much height. How did you secure yours in place? i can't find a way to get to the underside of the plasitc to put a bold in place. Link to comment Share on other sites More sharing options...
Member Contributer dutchinterceptor Posted October 2, 2009 Member Contributer Share Posted October 2, 2009 I put one on my other VFR and really like the setup with the integrated relay. Mine's not an abs but here's the location after a tiny bit of cutting on the plastic. I've tried that location, but it won't fit. I tried to use velcrove but it added to much height. How did you secure yours in place? i can't find a way to get to the underside of the plasitc to put a bold in place. As you can see from the pic above I had to cut part of the plastic off next to the master cylinder so it would fit. To attach it I just screwed it straight into the plastic fender/undertail. Also did the same with my Centech unit on my other bike except for cutting the plastic away. Link to comment Share on other sites More sharing options...
Member Contributer VFRiderGal Posted October 2, 2009 Member Contributer Share Posted October 2, 2009 Mine's tucked in under the seat under the back tail fairing... right side. (You can barely see it in the pic.) I really like the locations everyone else chose too! Very nice! Link to comment Share on other sites More sharing options...
