Member Contributer Knute Posted August 28, 2009 Member Contributer Share Posted August 28, 2009 Howdy All, Just kind of curious if anyone has had any issues with the Honda hard bags leaking? Link to comment Share on other sites More sharing options...
Member Contributer Ryanme17 Posted August 28, 2009 Member Contributer Share Posted August 28, 2009 No. The gasket to keep rain out does a very good job. Link to comment Share on other sites More sharing options...
Member Contributer VF1000R Posted August 28, 2009 Member Contributer Share Posted August 28, 2009 Never any issues and I have been through some downpours. Dirk Link to comment Share on other sites More sharing options...
Member Contributer Egg on Leggs Posted August 28, 2009 Member Contributer Share Posted August 28, 2009 If you have a wife like mine you will go touring with a large assortment of hair driers, straighteners and shoes you will find the will leak a touch due to overloading. Link to comment Share on other sites More sharing options...
DDO-VFR Posted August 28, 2009 Share Posted August 28, 2009 On occasion I've seen a slight water accumulation. IIRC it was always the left side (clutch side of the bike), when the bike stayed for extended periods in the rain while on the side stand, never while riding. Be sure to keep the gasket clean and watch you don't pinch stuff while closing, so that you don't damage the rubber. BI Link to comment Share on other sites More sharing options...
Member Contributer Knife Posted August 28, 2009 Member Contributer Share Posted August 28, 2009 I have Corbin Beetle Bags and they leak like a sieve. The lids don't even have the same exact contour as the bases. I'm going to swap them out for something else if I ever again have any discretionary spending money. Link to comment Share on other sites More sharing options...
Member Contributer Phormanluge Posted August 29, 2009 Member Contributer Share Posted August 29, 2009 Never any leaks; but as mentioned earlier, the top of the case around the closing mechanism may accumulate some water if the bike is left sitting in the rain (maybe a shot glass worth). Just make sure you towel it off a bit before opening it, or the water will spill into the case. Link to comment Share on other sites More sharing options...
Member Contributer Knute Posted August 29, 2009 Author Member Contributer Share Posted August 29, 2009 Thanks to All who gave feedback. I did recently purchased a used set and am now a little curious about leaks, suppose I should have asked before buying. :blush: Anyways, judging from what I read here, it seems I needn't be overly concerned about it. Thanks again. Link to comment Share on other sites More sharing options...
DDO-VFR Posted August 29, 2009 Share Posted August 29, 2009 Thanks to All who gave feedback. I did recently purchased a used set and am now a little curious about leaks, suppose I should have asked before buying. :blush: Anyways, judging from what I read here, it seems I needn't be overly concerned about it. Thanks again. CAREFULLY check the foam rubber gaskets on the lids looking for nicks, contusions, etc. as well as the any irregularities on the lip of the cases (bumps, nicks, dirt deposits). It doesn't take much to allow water to dribble in. When new, the VFR OEM cases are known to resist leaks very well, so there must be a compromise of the seals on yours. After your visual inspection slide your finger along the mating surfaces, Any irregularities can lead to leaks. BI Link to comment Share on other sites More sharing options...
Member Contributer Knute Posted August 29, 2009 Author Member Contributer Share Posted August 29, 2009 Thanks to All who gave feedback. I did recently purchased a used set and am now a little curious about leaks, suppose I should have asked before buying. :blush: Anyways, judging from what I read here, it seems I needn't be overly concerned about it. Thanks again. CAREFULLY check the foam rubber gaskets on the lids looking for nicks, contusions, etc. as well as the any irregularities on the lip of the cases (bumps, nicks, dirt deposits). It doesn't take much to allow water to dribble in. When new, the VFR OEM cases are known to resist leaks very well, so there must be a compromise of the seals on yours. After your visual inspection slide your finger along the mating surfaces, Any irregularities can lead to leaks. BI I haven't had the in-opportunity to test them in the rain yet (pretty much a fair weather rider for now) so I don't know yet if mine leak. My guess is they probably don't, as they appear to be in very good condition. I think I'll give them a good squirt with the garden hose to see what happens. Link to comment Share on other sites More sharing options...
