Member Contributer Ranger77 Posted June 20, 2009 Member Contributer Share Posted June 20, 2009 Another addition to you HF tire changer owners. http://www.harborfreight.com/cpi/ctaf/Disp...temnumber=66572 Link to comment Share on other sites More sharing options...
Tightwad Posted June 20, 2009 Share Posted June 20, 2009 Doesn't look like it would work for motorcycle tires, unless I misunderstand the intent. At least the HF tire changers don't use the arm that rides around the rim installing the tire, instead we use a bar. Link to comment Share on other sites More sharing options...
Guest Posted September 10, 2010 Share Posted September 10, 2010 Harbor freight has a manual fluid suction pump to draw engine oil and trans fluids through the dipstick tube. It looks like a gas can with a tire pump screwed onto it. Anyone own one of these and are they any good?I have a disability that makes getting back out from under the car a bit of work. But I'd like to know more before I buy one. Memphis Delivery Link to comment Share on other sites More sharing options...
Member Contributer RollinAgain Posted September 10, 2010 Member Contributer Share Posted September 10, 2010 Harbor freight has a manual fluid suction pump to draw engine oil and trans fluids through the dipstick tube. It looks like a gas can with a tire pump screwed onto it. Anyone own one of these and are they any good?I have a disability that makes getting back out from under the car a bit of work. But I'd like to know more before I buy one. I used to own one and I thought it sucked (no pun intended.) I threw it away and made my own using a mini wet/dry vac, a large pickle jar, 2 brass nipples, and some clear tubing. It works a treat for sucking oil out of all my lawn equipment and I also use it to bleed my brakes and clutch on the VFR :biggrin Rollin Link to comment Share on other sites More sharing options...
