Guest Netputty Posted August 18, 2008 Share Posted August 18, 2008 My RR has taken the dirtnap. Aside from beefing the wiring, does anyone have any recommendations on what to replace the OEM one with? '96 750. Thanks! Link to comment Share on other sites More sharing options...
Member Contributer rctwentyfour Posted August 18, 2008 Member Contributer Share Posted August 18, 2008 My RR has taken the dirtnap. Aside from beefing the wiring, does anyone have any recommendations on what to replace the OEM one with? '96 750.Thanks! Hello:I've gone back to the OEM Honda (Shindengen). However, my beloved mechanic WILL NOT install the ElectroSport any longer - they simply fail too much. He absolutely swears by Rick's: http://www.ricksmotorsportelectrics.com/ No, I have not used one myself; so, I guess that makes this a third-party endorsement. rctwentyfour Link to comment Share on other sites More sharing options...
Tightwad Posted August 21, 2008 Share Posted August 21, 2008 Ricks sells a good unit, and backs it up well also...this is what I resell. I prefer the 98-99 unit to the 90-97, but only because it has more surface area to bleed off the heat, as well as duplicated Positive and Ground output wires (instead of just a larger terminal). Ricks also makes an R/R without any connectors, which can be used in hardwire or remote mounting situations...very useful for those who want to customize the location to put it more in the airflow. Link to comment Share on other sites More sharing options...
Guest Posted September 5, 2008 Share Posted September 5, 2008 Thanks folks. The Rick's part works like a charm (and at half the price of OEM). Now to relocate it, since it doesn't mount flush. Air cooling fins for the win though! Link to comment Share on other sites More sharing options...
Member Contributer SAFE-T Posted September 6, 2008 Member Contributer Share Posted September 6, 2008 If you can fit a 5th gen unit in place, you can also substitute a CBR600RR peice. I replaced mine with an '04 model. Link to comment Share on other sites More sharing options...
Member Contributer Silver#788 Posted September 6, 2008 Member Contributer Share Posted September 6, 2008 04 r/1 rr works perfect for me but requires a little skill on the install I found mine on ebay used for $30 The fins are tall but easily cut down. Link to comment Share on other sites More sharing options...
