Guest vfroem Posted July 28, 2008 Share Posted July 28, 2008 For the last few kg's I want to buy ceramic brake discs (www.braketech.com) to put on my magnesium VFR750 front wheel. ? Which current motorbike has brakediscs with the same bolt pattern and offset as the VFR750 (RC36-II) front wheel ? Link to comment Share on other sites More sharing options...
SEBSPEED Posted July 28, 2008 Share Posted July 28, 2008 Current motorbike? Hmm... CBR600F3? Link to comment Share on other sites More sharing options...
Member Contributer JZH Posted July 29, 2008 Member Contributer Share Posted July 29, 2008 Nothing really modern uses 58mm bolt-circle disk mountings, but there were quite a few in the '90s. '94-'97 VFR750F had 296mm OD disks on 58mm bolt circle w/17mm offset (hub to outer disk face). So did: '95-'98 CBR600F '94-'97 CBR900RR '98-'07 VTR1000F If you want to go for 310mm OD disks, then: RC30 If you want to go for 310mm OD disks w/~5.5mm disk spacers: RC45/CBR1100XX (Use this info at your own risk!) Ciao, Link to comment Share on other sites More sharing options...
Guest Posted July 29, 2008 Share Posted July 29, 2008 Thanks ! At the moment I have brembo 320mm RC30 discs. Can someone tell me if the bolt circle / pattern and offset of the Ducati 916 is the same (as the VFR750)? Link to comment Share on other sites More sharing options...
Question
Guest vfroem
3 answers to this question
