Member Contributer JamieDaugherty Posted September 4, 2008 Member Contributer Share Posted September 4, 2008 arno-Where did you get this spacer? I am just sourced a 929 shock for my 4th gen, and am planning to do this swap. The spacer looks cleaner than using a pipe collar, I like it! I believe that is for the lower clevis to mount is brackets instead of the needle bearing, not for the upper mount. Link to comment Share on other sites More sharing options...
Guest Posted September 4, 2008 Share Posted September 4, 2008 arno-Where did you get this spacer? I am just sourced a 929 shock for my 4th gen, and am planning to do this swap. The spacer looks cleaner than using a pipe collar, I like it! I believe that is for the lower clevis to mount is brackets instead of the needle bearing, not for the upper mount. this spacer is not for the upper mount and is CNC machined Link to comment Share on other sites More sharing options...
flyguyeddy Posted March 20, 2009 Share Posted March 20, 2009 jamie, you can revalve 929 shocks to different springs? how much would u charge to do that to my previously "jamie'd" shock? i would like to try and sort out the preload stuff on my own. and i would like to run a 19kg/mm spring. (preload to be done with stock preload adjuster and some custom stuff) Link to comment Share on other sites More sharing options...
FinnRC36 Posted August 31, 2009 Share Posted August 31, 2009 Got my Jamied 929 shock mounted last week on my '91 and rode her a bit yesterday, feels awesome! With the VTR1000F Frankenwiffer front end and CBR 918RR brakes it's a sweet ride. Very comfortable and fast. Thanks again Jamie! Link to comment Share on other sites More sharing options...
