Baileyrock Posted March 13, 2008 Share Posted March 13, 2008 http://www.hrpworld.com/index.cfm?form_pro...;action=product I think a 6'' spring could work as that is only .4" shorter then required and I'm sure the pre-load adjuster could easially make up for that and your using a much heavior spring which should require less pre-load. :goofy: Link to comment Share on other sites More sharing options...
mechdziner714 Posted March 13, 2008 Share Posted March 13, 2008 Now the problem is HTF do you get the spring off. I have access to a spring compressor, but it pushes down on the split rings that hold the spring in place. So once its compressed the split ring is squished between the compressor & the spring and cannot be removed. If I use it from the other end its still under too much tension. I need a compressor that works from the outside of the spring. Those things are dangerous as hell too. Do they make a special spring compressor for MC shocks that grab the spring from the outside. I think Elka or Ohlins may be the way to go now :goofy: Link to comment Share on other sites More sharing options...
Guest Posted March 13, 2008 Share Posted March 13, 2008 Now the problem is HTF do you get the spring off. I have access to a spring compressor, but it pushes down on the split rings that hold the spring in place. So once its compressed the split ring is squished between the compressor & the spring and cannot be removed. If I use it from the other end its still under too much tension. I need a compressor that works from the outside of the spring. Those things are dangerous as hell too. Do they make a special spring compressor for MC shocks that grab the spring from the outside.I think Elka or Ohlins may be the way to go now :goofy: I usually get my rear springs from eshocks, they are between $72-80 each and I don't have to deal with Max who is a ripoff artist from the word go. You can also get a Penske built for the VFR, they custom build all their shocks. A friend of mine who has a FZ1 is getting a penske double clicker from JD Hord for about $750. JD is a rather infamous V twin race motor builder but he had about the cheapest price on a Penske my friend could find. http://www.eshocks.com/hyp_make.asp http://www.hordpower.com/ Link to comment Share on other sites More sharing options...
Baileyrock Posted March 13, 2008 Share Posted March 13, 2008 Now the problem is HTF do you get the spring off. Maybe a few drinks and a little sweet talk'en! :goofy: I wish I had a proper spring compressor! :pissed: Link to comment Share on other sites More sharing options...
