Poncho Posted August 11, 2007 Share Posted August 11, 2007 I am looking to get a 2nd set of rims for my 6th gen and I was wondering which years are compatible with the 6th gen. Also are there any other honda bikes that have a front rim that will fit the VFR? I am told maybe a F4, if so what years? I would like to keep the rear rim the same width. Thanks for the help. Link to comment Share on other sites More sharing options...
Member Contributer Motor_Ref Posted August 11, 2007 Member Contributer Share Posted August 11, 2007 I am looking to get a 2nd set of rims for my 6th gen and I was wondering which years are compatible with the 6th gen. Also are there any other honda bikes that have a front rim that will fit the VFR? I am told maybe a F4, if so what years?I would like to keep the rear rim the same width. Thanks for the help. 1990-1993 rears will fit 1998-2007 fronts and rears will fit Link to comment Share on other sites More sharing options...
Baileyrock Posted August 11, 2007 Share Posted August 11, 2007 I am looking to get a 2nd set of rims for my 6th gen and I was wondering which years are compatible with the 6th gen. Also are there any other honda bikes that have a front rim that will fit the VFR? I am told maybe a F4, if so what years?I would like to keep the rear rim the same width. Thanks for the help. 1990-1993 rears will fit 1998-2007 fronts and rears will fit :warranty: F4 fronts will work with stock VFR rotors. (F4 99-00) Link to comment Share on other sites More sharing options...
Poncho Posted August 11, 2007 Author Share Posted August 11, 2007 ok thanks but what about the 94 to 97 rear???? and are the 90 to 93 rear the same width?? I will be using these for trackdays so I would like them to be the same width Link to comment Share on other sites More sharing options...
Member Contributer Motor_Ref Posted August 11, 2007 Member Contributer Share Posted August 11, 2007 ok thanks but what about the 94 to 97 rear???? and are the 90 to 93 rear the same width??I will be using these for trackdays so I would like them to be the same width I have heard/read that there is some clearance problem with the '94 - '97 rear. I also believe that those are narrower than the others listed. All the ones I listed as compatible should be the same width. Link to comment Share on other sites More sharing options...
Member Contributer kwb377 Posted August 11, 2007 Member Contributer Share Posted August 11, 2007 '94 - '97 rear wheels will bolt on, but are 5" width...'90 - '93 and '98 - '07 are 5.5" width. Putting 3rd and 5/6th Gen rear wheels on '94 - '97 bikes requires slight modifcation to the wheel. Link to comment Share on other sites More sharing options...
Rogue Posted August 11, 2007 Share Posted August 11, 2007 '94 - '97 rear wheels will bolt on, but are 5" width...'90 - '93 and '98 - '07 are 5.5" width. Putting 3rd and 5/6th Gen rear wheels on '94 - '97 bikes requires slight modifcation to the wheel. Putting 5th/ 6th gen wheels on the 4th (and 3rd?) requires modification - no mods required to fit earlier wheels to later bikes..3rd gen is the golden choice :thumbsup: Link to comment Share on other sites More sharing options...
