Guest calvin3 Posted July 28, 2007 Share Posted July 28, 2007 can someone who has a zumo on their bike please explain how they hooked up the power code to the battery/fuse box and MORE importantly how the cable was hidden and protected? Link to comment Share on other sites More sharing options...
Member Contributer sportrider Posted July 28, 2007 Member Contributer Share Posted July 28, 2007 I bet the answer is in here: http://www.vfrdiscussion.com/forum/index.p...amp;hl=zumo+550 Link to comment Share on other sites More sharing options...
Member Contributer Silver#788 Posted July 29, 2007 Member Contributer Share Posted July 29, 2007 It hooks straight to the battery/ fusebox POS+ and NEG-. You will have to power it on and off with the button this way. You can also hook it to a relay off of your tail light. Would one of you electrical engineer type guys speak up here. Mine came wit both a connector for straight to the battery and a cig. plug type as well. Link to comment Share on other sites More sharing options...
Tightwad Posted July 29, 2007 Share Posted July 29, 2007 Powering via a Relay is easy, a 4-prong relay will tie in perfectly to the taillights, and the wires run right next to the battery so you can split the loom there and tapp into I believe it is a Green w/White wire. There should be 3 of them in there. Link to comment Share on other sites More sharing options...
Member Contributer BonusVFR Posted July 29, 2007 Member Contributer Share Posted July 29, 2007 I bet the answer is in here:http://www.vfrdiscussion.com/forum/index.p...amp;hl=zumo+550 Pictures and everything. Go switched. Link to comment Share on other sites More sharing options...
