Guest keithroxx Posted April 9, 2007 Share Posted April 9, 2007 I have an oppertunity to get a 6th gen aftermarket shock for cheap, but need to know if it will work. thanks Link to comment Share on other sites More sharing options...
Rogue Posted April 9, 2007 Share Posted April 9, 2007 I have an oppertunity to get a 6th gen aftermarket shock for cheap, but need to know if it will work.thanks They are not the same length, don't have the same stroke length and probably have a different spring rate, so no. However, you boys across the pond seem to just fit anything that'll physically bolt in there , so yes, It'll fit. :beer: Rod Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted April 9, 2007 Share Posted April 9, 2007 If the aftermarket shock has ride height adjustment, it'll probably work fine. Difference in shock length is 9mm (VTEC shock being shorter) Link to comment Share on other sites More sharing options...
Guest Posted April 9, 2007 Share Posted April 9, 2007 thanks Link to comment Share on other sites More sharing options...
Baileyrock Posted April 9, 2007 Share Posted April 9, 2007 I have an oppertunity to get a 6th gen aftermarket shock for cheap, but need to know if it will work.thanks The Vtec shock is the same POS as the stock 5th gen, you can get a CBR 929 shock for almost nothing and it's a much better, fully adjustable shock with the same factory spring rate as the vfr. Read any of the many 929 shock install post here. :thumbsup: Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted April 9, 2007 Share Posted April 9, 2007 I have an oppertunity to get a 6th gen aftermarket shock for cheap, but need to know if it will work.thanks The Vtec shock is the same POS as the stock 5th gen, you can get a CBR 929 shock for almost nothing and it's a much better, fully adjustable shock with the same factory spring rate as the vfr. Read any of the many 929 shock install post here. :thumbsup: He said it was an AFTERMARKET shock for a VTEC. Link to comment Share on other sites More sharing options...
Baileyrock Posted April 9, 2007 Share Posted April 9, 2007 I have an oppertunity to get a 6th gen aftermarket shock for cheap, but need to know if it will work.thanks The Vtec shock is the same POS as the stock 5th gen, you can get a CBR 929 shock for almost nothing and it's a much better, fully adjustable shock with the same factory spring rate as the vfr. Read any of the many 929 shock install post here. :thumbsup: He said it was an AFTERMARKET shock for a VTEC. Oh, :beer: , missed that! Don't be confusing me with the facts! <_< :blink: There should be aprox. 12mm of height adjustment on it if it has ride height adjustment that should make up the height difference no problem. If it doesn't have ride height adjust. you would just have to do a simple Mod to the top mount bracket and add a spacer. Link to comment Share on other sites More sharing options...
