MEZZANlNE Posted November 16, 2023 Share Posted November 16, 2023 (edited) I’ve been asked a few times to share this tail tidy, its a bit easier to install and less permanent than some of the other designs I’ve seen I printed it in black petg, 20% infill. It replaces the factory rear reflector. If you live in a country that requires a rear reflector I have another file for a bracket to mount an aliexpress reflector below the plate. Requires: - 2 holes to be drilled for licence plate bolts, these could be added in with your slicing software but it was easier for me to drill them - 2x 20mm M6 bolts to fix the plate (3/4” x 1/4”) - 1x 25mm M6 bolt to fix the tail tidy (1” x 1/4”) - 3x M6 nylock nuts (1/4”) - 6x M6 washers Tail Tidy v7.stl Edited November 16, 2023 by MEZZANlNE Clarity 3 Quote Link to comment Share on other sites More sharing options...
Member Contributer Captain 80s Posted November 16, 2023 Member Contributer Share Posted November 16, 2023 Is that the exhaust you run? Quote Link to comment Share on other sites More sharing options...
MEZZANlNE Posted November 17, 2023 Author Share Posted November 17, 2023 7 hours ago, Captain 80s said: Is that the exhaust you run? Nah. I have a delkevic short without the db killer, I find it sounds cool and I can hear it with earplugs, but its gets a bit quiet in heavy traffic once the bike is hot I tried just the midpipe both to see if it would be much louder but also to show off the rear wheel better, and if I liked it I was planning on getting a pipe made with a better angle. It sounded a bit tractorish so I didn’t bother. Coffman might be the answer but its overpriced Quote Link to comment Share on other sites More sharing options...
JohnMac Posted December 23, 2023 Share Posted December 23, 2023 Fantastic post!! Thankyou! Quote Link to comment Share on other sites More sharing options...
Member Contributer bmart Posted December 23, 2023 Member Contributer Share Posted December 23, 2023 That rear case is hanging WAY off there! Wheelies must be easy... Quote Link to comment Share on other sites More sharing options...
