2001 5th Gen Lights and instruments dead
Jlewis50
I have a 2001 Honda VFR 800 that has a dead instrument cluster and all lights. This is a new issue and happened when I was checking the wiring and a accidentally grounded a hot lead.
I thought it was just a fuse. All fuses are fine.
The bike cranks right up but every light function is now dead. Head lights, turn signals and instruments totally dead.
I’m thinking a relay as it’s not a fuse.
For all those lights to be dead AND you don't have a blown fuse then you most likely have a Ground fault. There is no relay that controls all those lights! Only your two Headlight relays. The common link between all these lights is the Ground for them and Fuse G 10amp !
Go through measuring the grounds of your lights. Make sure you get zero ohms/continuity back to the negative terminal of the battery for every Ground you check.
Do you have the Service Manual? You can download it from the forum. Do you have a multimeter and know how to use it?
