YosemiteVFR Posted January 21, 2021 Posted January 21, 2021 Hey guys, I’m in the middle of a brake fluid flush and taking the opportunity to install speed bleeders this time. I’m looking at the diameter of the threaded portion of the PCV bleeder valve (still installed) it appears to be bigger than the speed bleeder I have to replace it. Because of this I thought to ask before removing it. I tried searching for the answer to no avail. Does the 5th gen PCV take the same size bleeder as the rest of the system? Thanks in advance! Quote
Member Contributer raYzerman Posted January 21, 2021 Member Contributer Posted January 21, 2021 If you completely remove that bleeder, you'll see it is a unique design, nicely sealed with an o-ring, no reason to replace it. I don't know of a SpeedBleeder that would fit. 1 Quote
YosemiteVFR Posted January 21, 2021 Author Posted January 21, 2021 5 minutes ago, raYzerman said: If you completely remove that bleeder, you'll see it is a unique design, nicely sealed with an o-ring, no reason to replace it. I don't know of a SpeedBleeder that would fit. Thank you very much for that reply! I will leave it be and proceed. Quote
