Member Contributer Lannyl81 Posted December 23, 2019 Member Contributer Posted December 23, 2019 Searched for a carb kit for my '97, found two sources, both of which showed the contents; gasket for the float bowl, carb to air plenum, drain screw, float valve and a small "fat" O-ring...which I assumed to be for the pilot/fuel mixture screw. After purchasing a kit, then taking the carbs apart I found the pilot/fuel mixture screw O-ring to be considerably different. The O-rings I removed where about 1mm thick; the "fat" ones were 3+mm thick. I tried to get it to work, but would not....had to purchase additional O-rings. Now I am wondering if these "fat" O-rings were for somewhere else, perhaps the fuel enrichment/choke screw?....I did not take this apart....anyone happen to know? I have been emailing the company I got the kit from, which is in Poland, so there is a language barrier, trying to find-out more about these "fat" O-rings....not having much success. Appreciate any insight. Quote
Member Contributer Captain 80s Posted December 23, 2019 Member Contributer Posted December 23, 2019 Likely the o-rings for the float bowl drain screws. Quote
Member Contributer RC36B Posted December 23, 2019 Member Contributer Posted December 23, 2019 Or it could be the o-ring for the needle-assy in the slide piston Quote
Member Contributer Lannyl81 Posted January 6, 2020 Author Member Contributer Posted January 6, 2020 Not the O-ring for the drain screw, nor the O-ring for the slide needle.....these were included in the kit. I was able to measure the old O-rings and purchase new ones. The company in Poland responded saying they have sold these kits for years without any problems, so they refunded be $6. Of course the new O-rings were 3x times. Anyways all back together. Quote
Member Contributer RC36B Posted January 6, 2020 Member Contributer Posted January 6, 2020 But of course you ended up paying 3 times up 😞 We are lucky so many VFR 750 are still on the roads - that means kits are still around... I tried to find o-rings for the carburettors from o-ring suppliers... gave up - several have non-standard dimensions. Quote
