jstehman Posted July 11, 2019 Posted July 11, 2019 So this connector fell out from under my dash today Black wires on both sides it looks like..wires are connected and taped/heatshrunk Clutch switch? EDIT. It's the clutch switch. I disconnected the switch at the handle and she still started So now the question is Does the fuel map change when the switch is bypassed like this? On some Suzukis it changed the fuel map. Sent from my SM-N950U using Tapatalk Quote
Member Contributer Grum Posted July 11, 2019 Member Contributer Posted July 11, 2019 As far as I know the switch is normally open, and is only used for in gear, clutch in, start logic. 1 Quote
Member Contributer Grum Posted July 12, 2019 Member Contributer Posted July 12, 2019 12 hours ago, jstehman said: EDIT. It's the clutch switch. I disconnected the switch at the handle and she still started So now the question is Does the fuel map change when the switch is bypassed like this? Reckon you should repair the clutch switch wiring and not bypass it, you're creating a potentially dangerous situation. Quote
jstehman Posted July 12, 2019 Author Posted July 12, 2019 Yes, I probably should check into repairing the bypass. I still make it a habit of clutch in, neutral starts.. was just shocked to see that the previous owner didn't even try to clean out or adjust the switch at the perch before butchering up the wiring. Sent from my SM-N950U using Tapatalk Quote
