Silvo Posted May 28, 2017 Share Posted May 28, 2017 Hi all I have seen somewhere that someone had a problem with vibration which resulted in selling.. I have struggled with the same problem for a long time which I have finally resolved!!! I discovered that one of the oxygen sensors was fouled which caused cylinder 1&2 to run leaner than 3&4 !! Also check & clean the reed valves! ! This also causes throttle response issues.. silky smoothe now!!!!!!! Link to comment Share on other sites More sharing options...
Member Contributer swimmer Posted May 31, 2017 Member Contributer Share Posted May 31, 2017 How many miles on your VFR and how did you determine the O2 sensor was fouled? Link to comment Share on other sites More sharing options...
Silvo Posted June 2, 2017 Author Share Posted June 2, 2017 I had a slight vibration for many miles, got worse recently, so started checking sparkplugs ignition coils, injectors finally took out o2 sensors for inspection, the front one was oil fouled seems for a very long time.. decided to replace rather than try & clean.. too much work taking out radiator twice.. was relieved to to experience the smoothness & power !! Dct gearchanges are surprisingly smooth now.. I susspect it was cause d by oil overfill.. my experience is to rather not fill the oil to the top line but round 75%.. Link to comment Share on other sites More sharing options...
lshark Posted June 3, 2017 Share Posted June 3, 2017 i ALWAYS measure my oil when refilling....3.2 liters....it normally sits just above half way in the sight glass Link to comment Share on other sites More sharing options...
Silvo Posted June 3, 2017 Author Share Posted June 3, 2017 Half way is good .. I now wait long period for oil to run down before finalizing the fill. Interesting that you find it to be half way with precise measurement.. heard some people found it on the line or a tad over.. Link to comment Share on other sites More sharing options...
Silvo Posted July 3, 2017 Author Share Posted July 3, 2017 Just would like to add to the vibration issue.. My friend had the same problem with vibrations, we did the o2 replacement, there was an definite improvement but still some vibration.. Went down the line checked flow rate & presure of feul pump, eventually we cleaned the feul injectors . Problem FIXED super smooth & power he had not felt in quite a while.. Hope this helps for someone struggling out there.. My advice is clean the injectors every couple of years.. Gotta go mine is up for cleaning next.. Link to comment Share on other sites More sharing options...
