fultobt Posted November 27, 2016 Share Posted November 27, 2016 I have a 2003 with about 15k miles on it, have been getting a strange noise from the engine at idle once it is warmed up. It doesn't always happen, only intermittently. Any ideas? Link to comment Share on other sites More sharing options...
Member Contributer Grum Posted November 28, 2016 Member Contributer Share Posted November 28, 2016 Yep reckon there would be 100's of us on this forum that have heard that before. CCT's Cam Chain Tensioner. One for the front cyclinders and one for the rear. Try to establish wether its the front or rear cyclinders it's coming from. The rear one is a fair bit easier to replace than the front. Have a look through the forum and there is heaps of info on this topic. It's not uncommon after 15,000miles to start having CCT issues. Cheers. Grum Link to comment Share on other sites More sharing options...
fultobt Posted November 28, 2016 Author Share Posted November 28, 2016 12 hours ago, Grum said: Yep reckon there would be 100's of us on this forum that have heard that before. CCT's Cam Chain Tensioner. One for the front cyclinders and one for the rear. Try to establish wether its the front or rear cyclinders it's coming from. The rear one is a fair bit easier to replace than the front. Have a look through the forum and there is heaps of info on this topic. It's not uncommon after 15,000miles to start having CCT issues. Cheers. Grum Will look into, thanks! Link to comment Share on other sites More sharing options...
vegaquark Posted January 5, 2017 Share Posted January 5, 2017 Sell that and get a 5th gen Link to comment Share on other sites More sharing options...
Loftust Posted January 5, 2017 Share Posted January 5, 2017 51 minutes ago, vegaquark said: Sell that and get a 5th gen Or fit a 5th gen engine into a 6th gen Link to comment Share on other sites More sharing options...
vegaquark Posted January 5, 2017 Share Posted January 5, 2017 Or fit a 5th gen engine into a 6th gen Has anyone done that? I've read someone who changed de rear subframe from a 6th to a 5th but not what you said at all...I would like abs on a 5th gen. Link to comment Share on other sites More sharing options...
Loftust Posted January 6, 2017 Share Posted January 6, 2017 11 hours ago, vegaquark said: Has anyone done that? I've read someone who changed de rear subframe from a 6th to a 5th but not what you said at all... I would like abs on a 5th gen. I know of two guys in the UK who have done this, and I am in the process of doing this to my '02: There are probably a few owners stateside who have done the same - they generally seem to lead the way with such mods. Retaining the ABS should be fairly straightforward. Link to comment Share on other sites More sharing options...
Member Contributer jackleftzuo Posted January 6, 2017 Member Contributer Share Posted January 6, 2017 In China, we vfrchina club riders also a headache for this problem, recently many cyclists, try to change the timing chain, did not solve the problem, very hope to get the detailed solution, thank you, if is the tensioner problem, how to repair, replace or there are other ways? Link to comment Share on other sites More sharing options...
Member Contributer Grum Posted January 12, 2017 Member Contributer Share Posted January 12, 2017 On 6 January 2017 at 9:24 PM, jackleftzuo said: In China, we vfrchina club riders also a headache for this problem, recently many cyclists, try to change the timing chain, did not solve the problem, very hope to get the detailed solution, thank you, if is the tensioner problem, how to repair, replace or there are other ways? It's a common problem with the CCT's, the spring tension appears to drop off with age, and with slight added chain stretch, generally around the 40 to 50,000K's chain chatter can be the result. There is a fine line between the CCT applying just enough chain tension to avoid chatter and over tensioning the chain. Others claim the CCT itself can become noisey, the two experiences I've had it was purely chain chatter located in the upper cylinder head area, away from the CCT. Best fix is just to replace the CCT with a new item.. Link to comment Share on other sites More sharing options...
Member Contributer jackleftzuo Posted January 17, 2017 Member Contributer Share Posted January 17, 2017 Thank you for your advice, I will pass to all Chinese cyclists, hope to have the opportunity to meet with you, and riding on the road Link to comment Share on other sites More sharing options...
