Lint Posted November 7, 2015 Share Posted November 7, 2015 Ok, this is my 2005. This the area behind the seat latch. I noticed that the rear cowl is a little loose. The two stainless screws under the seat are in place, but the area around the taillight is loose. The light assembly itself is correctly attached, but the back of the cowl moves around. a little, light and all. If you look in the picture, it appears that the black plastic pin sticking through the hole is supposed to have some sort of barrel nut and screw in /over it. Do you know? I can't find anything on Bike Bandit in the schematic. The pin slides back and forth and if I could secure it, it would tighten up my loose part of the cowl. ......... If you look under the oval seals in this picture, you will see what I am talking about. If nothing is made, then maybe I can find something at Fastenal. I haven't peeked to see if there are threads in the spot that sticks through the hole, but if I can figure out a way to secure this, it would really solidify the backmost part of the cowl. Link to comment Share on other sites More sharing options...
Member Contributer ggathagan Posted November 7, 2015 Member Contributer Share Posted November 7, 2015 I don't think there are any screws intended for that.When removing the rear cowl, the service manual only discusses the 4 bolts holding the rear grab rails, the two screws that hold the rear cowl to the sub-frame up by the tank, and the two 5mm stainless pan screws that you mentioned.When I look at the parts fiche sections for the rear fender, the rear cowl, and the tail light, I don't see anything.The picture of the tail light in the service manual doesn't show much detail, but it only lists the four screws that attach the tail light to the rear cowl.I wouldn't be surprised if it was loose by design.Instead of trying to find a screw, I would suggest a rubber grommet or even electrical or foam tape to fill the space between the bosses on the tail light and the holes in the rear fender. Link to comment Share on other sites More sharing options...
Member Contributer RobF Posted November 7, 2015 Member Contributer Share Posted November 7, 2015 If you look in the picture, it appears that the black plastic pin sticking through the hole is supposed to have some sort of barrel nut and screw in /over it. Do you know? I can't find anything on Bike Bandit in the schematic. The pin slides back and forth and if I could secure it, it would tighten up my loose part of the cowl. You are referring to the circled piece below, yes? Mine looks like this: If I've understood you and am reading the fiche correctly, ggathagan is right and the missing piece is a grommet. The "rear combination light" parts fiche identifies callout tag 11 as: 80101-310-000 RUBBER, RR. FENDER CUSHION Note that there are two: left side and right side. Link to comment Share on other sites More sharing options...
Lint Posted November 7, 2015 Author Share Posted November 7, 2015 Thanks to both of you. I don't have the grab rails in, so I don't knew if having bolts there would make a difference. I'll definitely order up the rubber bushings, thanks for the research. Link to comment Share on other sites More sharing options...
Member Contributer ggathagan Posted November 7, 2015 Member Contributer Share Posted November 7, 2015 Nah, grab rails bolt directly to the sub-frame, so their presence or absence would have no impact. Link to comment Share on other sites More sharing options...
Member Contributer expvet Posted November 7, 2015 Member Contributer Share Posted November 7, 2015 And this is why VFRD rocks! Link to comment Share on other sites More sharing options...
Lint Posted November 7, 2015 Author Share Posted November 7, 2015 Agreed! Link to comment Share on other sites More sharing options...
Member Contributer The mailman Posted November 7, 2015 Member Contributer Share Posted November 7, 2015 Thank God for cell phone pics and VFRD! Link to comment Share on other sites More sharing options...
Member Contributer RobF Posted November 7, 2015 Member Contributer Share Posted November 7, 2015 On the topic of parts fiche (showing my age there, I doubt they're produced on fiche anymore), does anyone know what the "RR" suffix designates? I see it in many part names but am unable to decipher the abbreviation: FENDER ASSY. A, RR. REFLECTOR, RR. REFLEX PLATE, RR. FENDER Link to comment Share on other sites More sharing options...
Lint Posted November 7, 2015 Author Share Posted November 7, 2015 RR means rear Link to comment Share on other sites More sharing options...
Member Contributer RobF Posted November 7, 2015 Member Contributer Share Posted November 7, 2015 RR means rear I wouldn't have guessed that in a million years, but I guess it makes sense if you want a bookend match to "FR" for "front", especially since "R" alone was already taken by "right". Thank you. Link to comment Share on other sites More sharing options...
