Member Contributer flexiflyer Posted August 1, 2015 Member Contributer Share Posted August 1, 2015 If you look at aftermarket midpipes some of them weld the centerstand stop in the wrong spot or use to thin of a bumper so the stand goes "higher" than it shoud which takes tension off the springs......another culprit is if the spring lever notch/pin are worn it takes tension off the springs Link to comment Share on other sites More sharing options...
Member Contributer Rush2112 Posted August 4, 2015 Member Contributer Share Posted August 4, 2015 If you look at aftermarket midpipes some of them weld the centerstand stop in the wrong spot or use to thin of a bumper so the stand goes "higher" than it shoud which takes tension off the springs......another culprit is if the spring lever notch/pin are worn it takes tension off the springs Mine has ported and ceramic coated '99 VFR800 headers with the factory muffler and bumper, pin & notch were in good shape when the springs were installed... so this possibility doesn't apply for my clunkiness Sorry for the threadjack.... still love those 8 spokers! Link to comment Share on other sites More sharing options...
Tews19 Posted August 5, 2015 Author Share Posted August 5, 2015 20150414_163544_Ahart St.jpg Had to add one of the all time greatest Duc- Do you have a video of how your bike sounds? Link to comment Share on other sites More sharing options...
duccmann Posted August 5, 2015 Share Posted August 5, 2015 Tried once to post my lights on my top box, I will try again Link to comment Share on other sites More sharing options...
