Member Contributer adeyren Posted April 26, 2015 Member Contributer Share Posted April 26, 2015 Just about to install a Shendingen reg/rec on the bike (thanks "skids"). My existing wiring is slightly different to the Shendingen in that the bike has a black/white wire going to the existing reg but theres not one on the Shendingen. Anyone know what that wires for? Existing Shendingen Link to comment Share on other sites More sharing options...
Member Contributer mello dude Posted April 26, 2015 Member Contributer Share Posted April 26, 2015 Which R/R model do you have? Are you reusing an OEM Honda R/R? Probably not a good idea. - --You have charging system with a monitor wire. With a R/R upgrade you can ignore it. - Typically a newer Shindengen FH020AA R/R has 5 hook up points that use a connector, 3 for the stator, and 1 red for the positive side, and 1 black for ground. With this set up, wire strait to the battery with a HD 3 amp fuse holder on the positive side. Check as a reference www.roadstercycle.com Link to comment Share on other sites More sharing options...
Member Contributer adeyren Posted April 26, 2015 Author Member Contributer Share Posted April 26, 2015 Not got the Shindegen R/R to hand so will get the part no off it tomorrow. Will post then. Link to comment Share on other sites More sharing options...
