Member Contributer expvet Posted November 4, 2014 Member Contributer Share Posted November 4, 2014 My 06 Vtec has been idiling at 1200+ when I start it but goes to and stays at around 1500 once it warms up. I have tried to adjust via the adjuster cable near the rear brake pedal but the cable does not budge. Strange thing is the idle got to 1500 without any changes on my part. Any suggestions or things I should look for? My battery probably has seen it's last season, does the VFR up the idle trying to charge a weak battery? Link to comment Share on other sites More sharing options...
Member Contributer Polarbear Posted November 4, 2014 Member Contributer Share Posted November 4, 2014 Could the wax unit be out of wack?? C Link to comment Share on other sites More sharing options...
spud786 Posted November 6, 2014 Share Posted November 6, 2014 You need to use a Phillips screw driver while also turning the dial with a gloved hand. Really you ball park rpm is fine, 1350 or 1400 rpm is really ideal when warm. May not be worth messing with to drop 50 or 100 rpm. 1100 to 1300 rpm, I never really like the pros and cons of such. between 13 to 1500 warm is really Ideal. Im post 100,000 miles with such and mine runs mint and I hammer it all the time. Link to comment Share on other sites More sharing options...
