Member Contributer burnes45 Posted September 12, 2014 Member Contributer Share Posted September 12, 2014 I searched the forum for lowering the rear end and only found 2 posts. One mentioned you could rotate the triangle plates forward 1/3 of a turn and get 3/4 of an inch, There was a picture I don't know what generation it was but the plates had an arrow and were hollow in the middle. I looked at my '97 plates and they are solid with no arrows. Question is will rotating my plates lower my '97?? If not I'll buy lowering plates not that expensive but if I can save a little here I can spend it on something else. Sorry if I'm posting in wrong section but thought 3-4 gen owners would be more familiar with this. Any ones input would be appreciated. Thanks Dana. Link to comment Share on other sites More sharing options...
GadiantonRob Posted September 12, 2014 Share Posted September 12, 2014 I am fairly certain the 4th gens are designed to work just in one way, otherwise it will hit the swingarm/not align. The 5th/6th gens have a more triangled layout that can be flipped. You will have to go aftermarket. Link to comment Share on other sites More sharing options...
Dodi Posted November 25, 2014 Share Posted November 25, 2014 I searched the forum for lowering the rear end and only found 2 posts. One mentioned you could rotate the triangle plates forward 1/3 of a turn and get 3/4 of an inch, There was a picture I don't know what generation it was but the plates had an arrow and were hollow in the middle. I looked at my '97 plates and they are solid with no arrows. Question is will rotating my plates lower my '97?? If not I'll buy lowering plates not that expensive but if I can save a little here I can spend it on something else. Sorry if I'm posting in wrong section but thought 3-4 gen owners would be more familiar with this. Any ones input would be appreciated. Thanks Dana. Yes you can lower the bike by rotating the triangular plates......I cut a bit out the seat, flipped the plates and had my side stand cut as well. My 96 vfr definately sits lower and is a lot easier for me to ride......I am 5'4" tall with a 27 inch inseam....i am 58 years old by the way and ride my vfr everywhere. Link to comment Share on other sites More sharing options...
Member Contributer burnes45 Posted December 29, 2014 Author Member Contributer Share Posted December 29, 2014 I tried to rotate my plates and could find no combination where they would bolt on and not interfere with link or shock. In what direction did you "flip" them? Thanks. Link to comment Share on other sites More sharing options...
Tamworth Posted December 29, 2014 Share Posted December 29, 2014 I searched the forum for lowering the rear end and only found 2 posts. One mentioned you could rotate the triangle plates forward 1/3 of a turn and get 3/4 of an inch, There was a picture I don't know what generation it was but the plates had an arrow and were hollow in the middle. I looked at my '97 plates and they are solid with no arrows. Question is will rotating my plates lower my '97?? If not I'll buy lowering plates not that expensive but if I can save a little here I can spend it on something else. Sorry if I'm posting in wrong section but thought 3-4 gen owners would be more familiar with this. Any ones input would be appreciated. Thanks Dana. Yes you can lower the bike by rotating the triangular plates......I cut a bit out the seat, flipped the plates and had my side stand cut as well. My 96 vfr definately sits lower and is a lot easier for me to ride......I am 5'4" tall with a 27 inch inseam....i am 58 years old by the way and ride my vfr everywhere. It will completely alter the suspension geometry and shock travel in relation to swing arm travel. It is a very bad idea Link to comment Share on other sites More sharing options...
Member Contributer gll429 Posted December 29, 2014 Member Contributer Share Posted December 29, 2014 It will completely alter the suspension geometry and shock travel in relation to swing arm travel. It is a very bad idea technically, yes. but very few people wring all they can out of the bike. as long as the front is lowered to match ,its a tried a true mod that wont hurt anyone as long as they dont drag the bottom of the bike. Link to comment Share on other sites More sharing options...
