Member Contributer RRM Posted May 17, 2014 Member Contributer Share Posted May 17, 2014 Hi all, I am trying to remove the rear fender (the entire fender, not just the license plate part) so that I can remove my rear shock with remote pre-load. I have searched and cannot find any tips on removing the seat lock mechanism (this is the part I'm stuck on). I am installing a Ohlins rear shock (also with remote pre-load) and do not want to separate the pre-load and shock from each other. How do I get the seat lock undone? Any help would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
Member Contributer zoomzoom Posted May 17, 2014 Member Contributer Share Posted May 17, 2014 Being the owner of a 5th gen i I can't be of much help to your issue, BUT, here is a link to the download section of this site where you can download a copy of the Factory Honda Service Manual for your bike. This may be of some use, if you don't already have a copy that is. Hopefully someone else might chime in with some more definitive info. http://www.vfrdiscussion.com/forum/index.php/files/file/150-service-manual-6th-gen-2002-vtec-with-bookmarks/ Quote Link to comment Share on other sites More sharing options...
Member Contributer gmtech94 Posted May 17, 2014 Member Contributer Share Posted May 17, 2014 There is a black clip that holds it in place like a horseshoe clip pull it off and the lock is only attatched by the cable that goes to the latch assembly . It actually only takes a minute to remove the lock after that . 1 Quote Link to comment Share on other sites More sharing options...
Member Contributer RRM Posted May 17, 2014 Author Member Contributer Share Posted May 17, 2014 Excellent...i will go investigate. Thank you 94! Quote Link to comment Share on other sites More sharing options...
