I know this is probably repeated somewhere but after reading 25 threads I've run out of enthusiasm.
What is needed to put 43mm VFR fork tubes together with F4i legs. The goal is compression and rebound adjustability but with a longer fork (F4i about 15mm too short for my needs). I need at least 735mm overall length to the base of the cap.
Also, what mods should be carried out to get the best performance out of these forks while they're apart? Low friction seals, Racetech valving, polished rod, and . . . ?
Finally, what is the fully extended length of a VFR800 fork? I've searched all over and can't find a good answer. Are they the same as my 41mm RC36?
To avoid confusion, this setup is for a hybrid bike, hence me not having the parts on hand. I want to know I'm shopping for the right bits.
Question
93 VFR750 RC36
All,
6 answers to this question
