Fork Service ?
Got the 1.2's installed and raised the 5 wt fluid level from 160mm to 145mm. Rode today and it is definitely much better. Is it as good as it can possibly be ...probably not, but for $93 it is sweet!
I don't have a digital camera to post a pic, but the spacer is simply a piece of steel tubing cut to the necessary length. Attempted to use pvc pipe but it was to thick and wouldn't clear the internals of the cap. The stock spacer was just a thin piece of plastic!
Amazing that the thin plastic spacer didn't break apart when your forks were bottoming out!
Sent from my DROID RAZR HD using Tapatalk 2
Forks stiffened and serviced, Penske added, new tires front and rear, oil/filter change, calipers cleaned, brake/clutch fluid flushed and shorty levers added. Kinda anxious for a ride!
New tires? You mean you are NOT riding on cords? ;)
