interceptorrider Posted September 17, 2012 Share Posted September 17, 2012 Yesterday, while riding home, my PGM-FI light came on and remained on for last 12 miles home. Bike seemed to run fine. I got home, put the kickstand down in neutral and the light became intermittent (on for a bit, then off, on again, off, etc.). Shut it down, pulled out key, restarted and no light. Have not ridden it since due to a bad head/chest cold. My mods that may affect this are PwrCmndr V, LeoVince slip on (no valve, but removed cable in correct position), and Bazzaz Z-bomb. The last thing I added was the Z-bomb last winter (1500+ miles ago) without issue. I looked to see if there may be a short inline with my mods. Nothing noteworthy. Just wondering if anyone else has had an issue such as this. Thanks. Ride safe. Link to comment Share on other sites More sharing options...
vfrflanders Posted September 17, 2012 Share Posted September 17, 2012 It might have been the MIL. It's possible the problem solved itself. If it occurs again try to read the MIL. Then you know were to look. Link to comment Share on other sites More sharing options...
interceptorrider Posted September 17, 2012 Author Share Posted September 17, 2012 Uh, I don't mean to be stoopid, but, what the fruck is a MIL? Grassy Ass. Link to comment Share on other sites More sharing options...
vfrflanders Posted September 17, 2012 Share Posted September 17, 2012 MIL are (Honda) flash trouble codes. The ECM ( PGM FI) is equiped with self-diagnostic system and when a problem occurs the MIL starts to blink. These codes are known as DTC's (diagnostic trouble codes) The advantage of MIL is that you don't need special tools to analyse the problem. You can read it from your dash. Link to comment Share on other sites More sharing options...
Guest Posted September 17, 2012 Share Posted September 17, 2012 When my 1200F did that 2 months after buying it in 2010, the dealer did not believe me and it took 13 failures that got worse each time until they gave me a new ECU under warranty 11 months later. Link to comment Share on other sites More sharing options...
interceptorrider Posted September 18, 2012 Author Share Posted September 18, 2012 Where would I find the codes? Link to comment Share on other sites More sharing options...
pete2 Posted September 18, 2012 Share Posted September 18, 2012 It might be the O2 Optimizers that were installed together with PowerCommander. It has happened the you get a fault code after hard running. It normally disappears when you turn the key off and on. Link to comment Share on other sites More sharing options...
Dutchgixxer Posted September 18, 2012 Share Posted September 18, 2012 Where would I find the codes? The explanation of the codes is in the user manual. But if you tell me the # long blinks and the # short blinks i am willing to look up the code and tell you the error. Link to comment Share on other sites More sharing options...
Dutchgixxer Posted September 18, 2012 Share Posted September 18, 2012 It might be the O2 Optimizers that were installed together with PowerCommander. It has happened the you get a fault code after hard running. It normally disappears when you turn the key off and on. Check if there is a firmware update in your PC-v possible. To upgrade the firmware first upgrade the powercommander sw on your pc, after you did thet you have the possibility to upgrade the firmware to the latest version. ( there was a dropped cilinder issue solved in the latest firmware. ) The firmware update is in 2 steps. first the boatlader is upgraded then the firmware of the PC-V. So it is nessesary to try several times to upgrade before you are done. Backup you maps first. Link to comment Share on other sites More sharing options...
interceptorrider Posted September 18, 2012 Author Share Posted September 18, 2012 OK, first thanks. This is a great web board. I was hard on the gas when the light came on and the bike wasn't completely warmed up. Something I rarely do. I have not updated my firmware on my PC. When I said it "seemed to run fine," it did seem slightly off but I couldn't put my finger on it. Dropping a cylinder on a high horsepower bike when you are now backing off the throttle is less noticeable than on my 800cc v-twin Ducati. The dropped cylinder theory may be a good one. I will ride today and see what happens and how it feels. Thanks again for all the input. Ride safe. Link to comment Share on other sites More sharing options...
interceptorrider Posted September 18, 2012 Author Share Posted September 18, 2012 Took about a 20 mile ride today with my congested head and it was fine. Smooth and powerful as always with no light. Perhaps it was an anomaly. Thanks again. Ride safe. Link to comment Share on other sites More sharing options...
pete2 Posted September 19, 2012 Share Posted September 19, 2012 Check if there is a firmware update in your PC-v possible. To upgrade the firmware first upgrade the powercommander sw on your pc, after you did thet you have the possibility to upgrade the firmware to the latest version. ( there was a dropped cilinder issue solved in the latest firmware. ) The firmware update is in 2 steps. first the boatlader is upgraded then the firmware of the PC-V. So it is nessesary to try several times to upgrade before you are done. Backup you maps first. This is good info, Thanks . Link to comment Share on other sites More sharing options...
interceptorrider Posted September 19, 2012 Author Share Posted September 19, 2012 Rode it 4 times today for a total of 40 miles or so. No issues. Works good. Lasts long time. Ride safe. Link to comment Share on other sites More sharing options...
