FrankoQ Posted July 24, 2012 Share Posted July 24, 2012 Finally got mine done. A few comments and pics of my install. what comes with the package: for more details, see the original install guide: remove left and right fairings. replace coolant bottle and install it. remove engine rod and push new one in. new rod going in: Old one coming out: It should look like this: Now to the scary part. making holes on the fairings. I used plumber's putty. :) this helped me know exactly where to start the holes. used a small drill bit for initial hole. then moved to larger bit and ended up using a dremmel for the rest. That's it. most of the time is spent making those holes big enough for the spacers to go thru. 1 Quote Link to comment Share on other sites More sharing options...
Metallican525 Posted July 24, 2012 Share Posted July 24, 2012 Eeeeeeexxactly. Well put, pretty straitforward and simple install right? I like the plumbers putty idea better than paint like I used, good thinkin!! Quote Link to comment Share on other sites More sharing options...
