Member Contributer VFR Capt.Bob Posted July 16, 2012 Member Contributer Share Posted July 16, 2012 I upgraded my rear shock to an elka with correct spring rate then changed fork oil wt. And fork springs to match. I wasn't happy at all with the suspension until I did full racetech comp and reb and had race tech set it up to match the rear shock and my riding style. Night and day especially when sport riding or track days. Just do it and the sooner the better. Link to comment Share on other sites More sharing options...
Guest Posted August 6, 2012 Share Posted August 6, 2012 Would it be advisable if I just installed the RT Gold Valves without changing the springs? Link to comment Share on other sites More sharing options...
Baileyrock Posted August 7, 2012 Share Posted August 7, 2012 Would it be advisable if I just installed the RT Gold Valves without changing the springs? Depends on how much you weigh! If it's around 140-150 lbs you might be OK, but the springs are the foundation of suspension building. BR Link to comment Share on other sites More sharing options...
Guest Posted August 7, 2012 Share Posted August 7, 2012 Would it be advisable if I just installed the RT Gold Valves without changing the springs? Depends on how much you weigh! If it's around 140-150 lbs you might be OK, but the springs are the foundation of suspension building. BR Looks like i am out of budget again! Am 88 kg....thats around 194lbs and the bike now has hard bags....thanks Bailey. Link to comment Share on other sites More sharing options...
