Grilldemon Posted April 15, 2012 Share Posted April 15, 2012 Watching my voltmeter while synching my carbs a couple weeks ago. Hitting 15-15.3 volts at idle. R/R getting real warm. After reading tons of posts about using cpu fans to cool this vital component, I started to think about doing same. I found a fan at the local electronics supply: I scavenged some metal standoffs from an old computer carcass I had lying around (sometimes it pays to be a packrat) and secured them between the fins with some Devcon Plastic steel (something that should be on every workbench) With the mounts secured, I cleaned the fins with emery cloth and some lacquer thinner (another must have in the shop) and applied thermal grease and screwed down the mounts. It's a little small, but I don't have much room between the side panel and R/R. The body and fins are copper, so it should help draw the heat. It is set up to draw air in. My computer buddy told me I can reverse the polarity and it will reverse the fan rotation. I'll try it both ways, see which one works better. This is on my 84 VF1000F with 53,000km. The stator checks out fine. At idle, I get 13.8 volts with the fan on. I will have to replace the R/R eventually. For $20.00, it'll hold me over till I get a new one. Also gonna get a new stator and have it on the shelf. Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted April 15, 2012 Share Posted April 15, 2012 I had a standard PC case fan on mine for awhile. Tapped the power from the license plate light circuit. After awhile, the fan quit, I assume it didn't like living outdoors. I never replaced it. Link to comment Share on other sites More sharing options...
smoothsailin Posted April 15, 2012 Share Posted April 15, 2012 The connector below and to the right of the RR looks to be in bad shape. Link to comment Share on other sites More sharing options...
Grilldemon Posted April 16, 2012 Author Share Posted April 16, 2012 The connector below and to the right of the RR looks to be in bad shape. Actually, internally, it's in good shape, clean terminals and fresh dielectric. The exterior of it could use a scrub. PO had some kind of black goo all over it. Link to comment Share on other sites More sharing options...
Member Contributer AnikMankar Posted May 17, 2012 Member Contributer Share Posted May 17, 2012 Link to comment Share on other sites More sharing options...
Member Contributer vfr350 Posted June 3, 2012 Member Contributer Share Posted June 3, 2012 This fan is my 2nd attempt, It actuall works great as it fits just perfectly to draw in cool air from the vent on the side of the cowl and surprisingly pushes alot of air cross it and out the back. The aluminum bracket actually gives more surface area to transfer heat on the back as well. Link to comment Share on other sites More sharing options...
Member Contributer AnikMankar Posted June 12, 2012 Member Contributer Share Posted June 12, 2012 This fan is my 2nd attempt, It actuall works great as it fits just perfectly to draw in cool air from the vent on the side of the cowl and surprisingly pushes alot of air cross it and out the back. The aluminum bracket actually gives more surface area to transfer heat on the back as well. Nice.... What fan is this....looks like it is working like a blower Link to comment Share on other sites More sharing options...
bayarearider Posted June 12, 2012 Share Posted June 12, 2012 Just did the same (wired to the fuse block) to cool that hot spot. We'll see... Link to comment Share on other sites More sharing options...
Member Contributer vfr350 Posted June 19, 2012 Member Contributer Share Posted June 19, 2012 It was just a PC slot fan, but yes it is a blower right out the straight side towards the back. Link to comment Share on other sites More sharing options...
Member Contributer AnikMankar Posted June 28, 2012 Member Contributer Share Posted June 28, 2012 Just did the same (wired to the fuse block) to cool that hot spot. We'll see... I think it will still run a little hot as it is close the radiator... Link to comment Share on other sites More sharing options...
