jbackus4 Posted April 13, 2012 Share Posted April 13, 2012 Tapp Lite USB Charger Hey Everyone, I was wondering if anyone had installed one of these? I bought it but I'm having a difficult time finding a good spot. I could have opted for the Powerlet for the center of the bars but I have a Ram-Mount there to hold my GoPro and another Ram-Mount installed onto the two bolts that hold the gas tank so this was my only option. http://www.3brpowersports.com/TAPP_lite.htm If you've installed one, could you send a picture of where you placed the port? Thanks, JohnB Link to comment Share on other sites More sharing options...
wera803 Posted April 13, 2012 Share Posted April 13, 2012 I was thinking about getting one of those too. I would probably just zip-tie it to the brake/clutch line or wiring harness going to the handlebars though. Not sure I would really "mount" it somewhere in particular. Link to comment Share on other sites More sharing options...
VietHorse Posted November 8, 2012 Share Posted November 8, 2012 I have a look alike USB socket. It made by BurnsMoto: http://burnsmoto.com...eatherproof.php They shipped directly to me in Vietnam. All for cheaper than the Tap Lite USB. This is exactly what I got, including a BurnsMoto sticker: I choose to install the socket attaching to the side frame, by the ABS controller 's bolt. When I use the original plastic clamp, it came to be like this: However, I think I was lucky that the clamp broken when I tried to tighten it. Much better than it would break itself while riding due to vibration or over heated. It's not too difficult to make a replacement - May not be so nice but it fits and works great: Here is how the socket is installed: There is still a reasonable air gap btw the front fork and the socket: Overview: I connected the wire directly to the battery (not going thru the ignition lock). I also added a 1A fuse and a ON/OFF switch. I am still not sure where I should locate the On/off switch. All are now under the seat: Next is to find the best location for the switch, and find something to modify the USB pin as the waterproof one. ($10 for the rubber seal from BurnsMoto is too much) Link to comment Share on other sites More sharing options...
wera803 Posted November 8, 2012 Share Posted November 8, 2012 I actually ended up with the BurnsMoto one as well. I didn't permanetly mount it though. I just put an SAE 2-pin connector on it so I can plug it into my Battery Tender lead and charge things as needed. It is long enough to reach my saddle bag or tank bag. I can also let my girlfriend use it on her bike if she needs to charge something since she has a Battery Tender lead as well. Link to comment Share on other sites More sharing options...
SEBSPEED Posted November 8, 2012 Share Posted November 8, 2012 Good idea Ken. Link to comment Share on other sites More sharing options...
