Guest teomac Posted June 23, 2011 Share Posted June 23, 2011 Hi everybody! I hope it's not a problem that my first post is here. Been a VFR owner for a while and member of this forum for a short time. I live and commute on a VFR daily...well, until the rectifier almost set my bike on fire! Really, that's how much smoke it put out! So please those knowledgeable enough tell me whether a 1996 VFR750 model (used ofcourse) could fit my 1992 VFR750? THANKS! Link to comment Share on other sites More sharing options...
Member Contributer RollinAgain Posted June 23, 2011 Member Contributer Share Posted June 23, 2011 Yes it will work but in all honesty you really need to replace the wiring harness as well. I would also advise using a more heavy duty aftermarket R/R versus any OEM unit. Check out the link below. http://www.wiremybike.com/index.php?cPath=1_16&osCsid=288a2156596fcf9fa61dc963937be703 Rollin Link to comment Share on other sites More sharing options...
Guest Posted June 23, 2011 Share Posted June 23, 2011 Yes it will work but in all honesty you really need to replace the wiring harness as well. I would also advise using a more heavy duty aftermarket R/R versus any OEM unit. Check out the link below. http://www.wiremybike.com/index.php?cPath=1_16&osCsid=288a2156596fcf9fa61dc963937be703 Rollin Thank you! This really helps, I appreciate. I would set out to check the wiring as well. Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted June 24, 2011 Member Contributer Share Posted June 24, 2011 Is the R/R you have a flat pack or does it have cooling fins? If the former, you may want to add a heatsink... Link to comment Share on other sites More sharing options...
Guest Posted August 15, 2011 Share Posted August 15, 2011 Is the R/R you have a flat pack or does it have cooling fins? If the former, you may want to add a heatsink... Sorry, I wasnt aware of your post since I've also gotten the problem fixed. Yes, the one I got has the fins and it's from a '96 model. So far it works! Thanks for your input though! Link to comment Share on other sites More sharing options...
