VFRness and Aux Power arrived
AnikMankar
Long awaited package containing the VFRness and the Steering head aux power has arrived. Once i get the aux fuse box will start working on this. Will post the pictures
So started work on the fusebox harness...
1) the fuse box
2) the inline fuse and relay to power the fuse box. (still WIP - have to put the heat shrink tubes). the fuse wire to the battery is black, need to make it red.
3) the complete harness. the Power trigger from the signal/rear break switch is pending. will add that on the weekend.
1) the fuse box
I am curious to see where you mount it. That fuse block is taller than the one I sell as mine has inputs on the sides, not the bottom...could be easier to manage if it will fit height wise.
The plan is to have it fitted on the battery cover using push clips. There is just enough space after the seat is fitted. Will send pictures when its done.
  • 5 weeks later...
So had to re-look at the way i had made the harness. So ended up with this.
Clockwise from top...
- Power source with clips...i can unplug it if not required. (purple)
- 6 blade Fusebox
- Battery +ve (red) and -Ve (Black)
- Relay
- Fusebox to Battery
Managed to snug fit the fuse box on the battery cover with 2 x 5mm push clips.
Top view..
Tapped into the Rear brake power (Black/yellow) , soldered and got it taped
Now to connect the Accessories
- Rectifier Fan
- Coming soon -- Shift light , Voltage meter and the Handle Powerjet
