Member Contributer AnikMankar Posted January 8, 2010 Member Contributer Share Posted January 8, 2010 Having replaced all the bulbs to LED, the signal was blinking faster than normal. I did try to fit the resistors across but didnt work. So i had ordered the LED flasher. LED Blinker - Step1 Purchased a couple of connectors from the hardware store and used one set of old wiring. LED Blinkers - Step 2 LED Blinkers - Step3 The problem was connecting the wiring to the existing harness. I tried using an old connector i had but didnt work so i bypassed and connected the wires directly to the harness LED Blinkers - Step5 Finally looked like this. LED Blinkers - Step4 Took an hour to get this done right but it worked. Quote Link to comment Share on other sites More sharing options...
Member Contributer Jmmymc750 Posted January 8, 2010 Member Contributer Share Posted January 8, 2010 Looks like nice work! Thanks for the pics! Quote Link to comment Share on other sites More sharing options...
Member Contributer Jmmymc750 Posted January 8, 2010 Member Contributer Share Posted January 8, 2010 P.S. Where did you get the relay? how much? I think I have seen a thread with info on sourcing the LEDs already, but the only place I know for the relay is Thurn... Quote Link to comment Share on other sites More sharing options...
Member Contributer coderighter Posted January 8, 2010 Member Contributer Share Posted January 8, 2010 Or you could do this. You need to scroll down to post #7. The flasher is the same as my '06 hazard. http://www.zrxoa.org/forums/showthread.php?t=85306 Or if you don't want to open one up, for $15 you can plug and play with this. http://www.customdynamics.com/trick_flasher.htm#Standard_DOT_Flasher If you have an '06 or newer, it's a whole differant bag of worms! See here- http://www.vfrdiscussion.com/forum/index.php?showtopic=56459&st=0&p=668170&fromsearch=1entry668170 Quote Link to comment Share on other sites More sharing options...
Member Contributer AnikMankar Posted January 9, 2010 Author Member Contributer Share Posted January 9, 2010 P.S. Where did you get the relay? how much? I think I have seen a thread with info on sourcing the LEDs already, but the only place I know for the relay is Thurn... the flasher i picked from eBay for about GBP 14 plus shipping. http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=400078468537&viewitem=&sspagename=ADME%3AL%3AOU%3AMOTORS%3A1123 Quote Link to comment Share on other sites More sharing options...
