tinyminds Posted February 8, 2007 Share Posted February 8, 2007 Was raising my forks up the way I had them before I took the bike in for warranty work on throttle cables, figured I would do How-To in case anyone was interested that was unsure what to do. Enjoy! Cover tank before you start, in case you drop a wrench or something. I've learned from experience. Edit: Forgot to mention, raise the front of the bike up before you start. The bike will come crashing down from the weight when you loosen the 4 triple clamp bolts if you don't. I put mine on the center stand and pulled the back down with a tie-strap. Quote Link to comment Share on other sites More sharing options...
Forum CEO HispanicSlammer Posted December 21, 2008 Forum CEO Share Posted December 21, 2008 Was raising my forks up the way I had them before I took the bike in for warranty work on throttle cables, figured I would do How-To in case anyone was interested that was unsure what to do. Enjoy! Cover tank before you start, in case you drop a wrench or something. I've learned from experience. Edit: Forgot to mention, raise the front of the bike up before you start. The bike will come crashing down from the weight when you loosen the 4 triple clamp bolts if you don't. I put mine on the center stand and pulled the back down with a tie-strap. Quote Link to comment Share on other sites More sharing options...
