marid2apterbilt Posted March 26, 2008 Share Posted March 26, 2008 Well i got a set of gmrs radios ( audiovox gmrs1072) and would like to use them with some sort of helmet speaker/mic setup but cant find any tech spec as to what pin/connection it uses. So far i have figured out it uses a 3.5 mm single pin.. I have looked over the Audiovox, firefox, and Iasus + many others but cant find these gmrs radios listed as compatible or specs for the connection.? Are all audiovox the same for the connection pin of a helmet spkr/mic.? Does anyone know what other brands use the same possible connector? Thanks for any help.... Link to comment Share on other sites More sharing options...
Member Contributer BonusVFR Posted March 27, 2008 Member Contributer Share Posted March 27, 2008 Well i got a set of gmrs radios ( audiovox gmrs1072) and would like to use them with some sort of helmet speaker/mic setup but cant find any tech spec as to what pin/connection it uses.So far i have figured out it uses a 3.5 mm single pin.. I have looked over the Audiovox, firefox, and Iasus + many others but cant find these gmrs radios listed as compatible or specs for the connection.? Are all audiovox the same for the connection pin of a helmet spkr/mic.? Does anyone know what other brands use the same possible connector? Thanks for any help.... I have an Vox frs/gmrs radio. It uses a 3.5mm plug. I have a 3.5mm plug I use with an IMC headset/mic on the VFR. Sierra Electronics sells them. I also use the radios on the Wing but that is a special hookup. Lesson learned for me TOOOOOOOOO. Buy and the speaker/headset first and then find a radio that works with it. There is zero standards for the hookups. Frustrating to say the least. Link to comment Share on other sites More sharing options...
Guest Posted March 27, 2008 Share Posted March 27, 2008 I have an Vox frs/gmrs radio. It uses a 3.5mm plug. I have a 3.5mm plug I use with an IMC headset/mic on the VFR. Sierra Electronics sells them. I also use the radios on the Wing but that is a special hookup.Lesson learned for me TOOOOOOOOO. Buy and the speaker/headset first and then find a radio that works with it. There is zero standards for the hookups. Frustrating to say the least. Planetheadset.com sells a 3-piece headset - speaker/mic, PTT button, and radio connector. You buy the connector that fits your radio. Link to comment Share on other sites More sharing options...
marid2apterbilt Posted March 27, 2008 Author Share Posted March 27, 2008 Thanks for the replys. I have been looking at these.. http://helmetaudio.com/khxc/index.php?app=...ow&ref=MI34 + the hs36 speakers.. Has anyone tried these.. I sent them a email with some questions.. Link to comment Share on other sites More sharing options...
Member Contributer BonusVFR Posted March 27, 2008 Member Contributer Share Posted March 27, 2008 As a sidenote -- one benefit of the audiovox 3.5 mm plug is that the same headset will work with a ipod, Zune or Zumo too. But you can not use multiple devices at the same time without some other piece of kit. No standards for audio hookups.................this is a problem. Link to comment Share on other sites More sharing options...
