OGBiker Posted March 24, 2008 Share Posted March 24, 2008 Looking to upgrade my lighting and want to setup HIDs on my 2K VFR. Anyone have any kit recommendations? I am looking for an HID kit that is able to provide low beam and high beam lighting. Link to comment Share on other sites More sharing options...
Darth Bling Posted March 24, 2008 Share Posted March 24, 2008 Looking to upgrade my lighting and want to setup HIDs on my 2K VFR. Anyone have any kit recommendations? I am looking for an HID kit that is able to provide low beam and high beam lighting. I found a few threads that might be helpful: http://www.vfrdiscussion.com/forum/index.php?showtopic=3125 http://www.vfrdiscussion.com/forum/index.php?showtopic=38440 http://www.vfrdiscussion.com/forum/index.php?showtopic=28450 http://www.vfrdiscussion.com/forum/index.php?showtopic=31607 http://www.vfrdiscussion.com/forum/index.php?showtopic=35670 http://www.vfrdiscussion.com/forum/index.php?showtopic=34825 http://www.vfrdiscussion.com/forum/index.php?showtopic=34260 Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted March 24, 2008 Share Posted March 24, 2008 HID lighting in a non-HID housing is sketchy at best. The reflector shape is not designed for HID capsules, and the beam dispersion pattern can be less than optimal. Problem being, the cutoff is very high and blinds oncoming drivers. Most HID retrofits force you to lose the lowbeam function. A few setups will use an auxiliary halogen bulb piggybacked to the HID capsule for dual-beam operation, but again, capsule placement is not optimal. Then there is the "shuttered" bulb that uses a sliding shutter to alternate between low and high. Not sure if those are reliable or not, but they probably suffer from the same dispersion woes as they are, once again, using the wrong headlamp reflector design, one that was designed and optimized for halogen bulbs. So for me, HID conversion is more about "what are you willing to lose?" Info: http://www.danielsternlighting.com/tech/bu...onversions.html Link to comment Share on other sites More sharing options...
OGBiker Posted March 24, 2008 Author Share Posted March 24, 2008 Thanx for the info. I was looking at this motorcycle HID kit because it is supposed to be able to do high and low beams. Anyone familar with this kit? http://www.kbcarstuff.com/4300k_Motorcyle_...-h-fslash-l.htm Link to comment Share on other sites More sharing options...
Question
OGBiker
3 answers to this question
