Guest hougy Posted January 5, 2008 Share Posted January 5, 2008 When I was testing out the lighting on my new VFR, I noticed the handbrake does not activate the brake light. The foot brake will once you put "enough" pressure on it (a little to much IMO). I am not familiar with the VFR since I just got it, and I don't know where all the fuses are yet. Can anyone lend a suggestion of what to look at? Link to comment Share on other sites More sharing options...
squirrelman Posted January 5, 2008 Share Posted January 5, 2008 failure of the small brake light switch is common, so pull the 2 wires off the switch, peel back the rubber booties and touch wire terminals together. IF the lights go on, you need to replace the switch. (if your rear brake light is working there's no problem with a fuse, but on a new bike, especially a Honda, you need to find the fuses box for future reference....you may be needing it!) you'll need to unfasten the 2 bolts holding the brake set-up to the handlebar for best access to switch, which is held in place by one very small screw....don't loose it! Link to comment Share on other sites More sharing options...
Member Contributer kwr8728 Posted January 5, 2008 Member Contributer Share Posted January 5, 2008 As for the rear brake, you can adjust the height at which the light comes on by adjusting the screw nob on the brake light switch down by the foot pedal. It is near the rear master cylinder. Black Plastic piece that has threads...and a little metal hook on the bottom attached to the foot pedal. Link to comment Share on other sites More sharing options...
Member Contributer kwr8728 Posted January 5, 2008 Member Contributer Share Posted January 5, 2008 oh and if your y2k is like my 98 the fuse box is underneath the seat on the outside of the battery box... right near the gas tank. Link to comment Share on other sites More sharing options...
Guest Posted January 5, 2008 Share Posted January 5, 2008 Awesome. Took it off and fiddled around with it. It works now o.O I think I'll go and get a spare just incase...that screw was a freaking bugger Link to comment Share on other sites More sharing options...
