Guest none Posted May 26, 2007 Share Posted May 26, 2007 Hi guys, Found a loose connection in my 6th gen VFR near the 30amp main fuse. What is it? Looks like thick ground cable. I had connected it to the neg connection of the battery, will that be all right? Thanks Link to comment Share on other sites More sharing options...
turtlecreek Posted May 26, 2007 Share Posted May 26, 2007 does your bike run without it? not sure just from the photo, but it does look like you need to replace the 30amp fuse holder/wires as you can easily see the browning on the case and the blackening of the wires from the heat.....failure is only a "long ride in the middle of no where" away! Link to comment Share on other sites More sharing options...
Guest Posted May 26, 2007 Share Posted May 26, 2007 Yes it does run without it connected or with it connected to the ground. Link to comment Share on other sites More sharing options...
Baileyrock Posted May 26, 2007 Share Posted May 26, 2007 It's not a factory wire! Check to see where it runs to, maybe it's the previous owners attempt for an extra bike ground. :rolleyes: Link to comment Share on other sites More sharing options...
Guest Posted May 27, 2007 Share Posted May 27, 2007 Yeah, I will do a trace. thanks It's not a factory wire! Check to see where it runs to, maybe it's the previous owners attempt for an extra bike ground. :rolleyes: Link to comment Share on other sites More sharing options...
