Guest BIGTWAN251975 Posted May 11, 2007 Share Posted May 11, 2007 i was on my way home today then bam the FI light came on . so i got home did the code chasing and it blinked 8 times. ok now my question what does the TP do and will this hurt my bike if i ride it this way cus right now this all i have to get around and how do i fix it ???? Link to comment Share on other sites More sharing options...
Forum CEO HispanicSlammer Posted May 11, 2007 Forum CEO Share Posted May 11, 2007 Throttle postion sensor, probably not the actual sensor but the wire harness connecting to it. pull it apart (on the throttle bodies) and clean the connections. Link to comment Share on other sites More sharing options...
Guest Posted May 12, 2007 Share Posted May 12, 2007 thks Link to comment Share on other sites More sharing options...
Guest Posted May 12, 2007 Share Posted May 12, 2007 i was on my way home today then bam the FI light came on . so i got home did the code chasing and it blinked 8 times. ok now my question what does the TP do and will this hurt my bike if i ride it this way cus right now this all i have to get around and how do i fix it ???? How do you get the error codes? Is there a scanner you bought or a procedure to get them to blink on the instrument panel? Thx, Chris Link to comment Share on other sites More sharing options...
Member Contributer Rivcyko Posted May 12, 2007 Member Contributer Share Posted May 12, 2007 If it doesn't work, post back. DO NOT REMOVE THE SENSOR. It is preset, from the factory. Link to comment Share on other sites More sharing options...
