2003_VTEC_Rider Posted November 10, 2006 Share Posted November 10, 2006 It is a bunch of hype. Won't they don't tell you, is the lack of moisture in what they pump into your tires is the key. If you have a good compressor set up with a water vapor filter you get the same results. Just another thing I want to add to the garage this winter. I wonder if I can sell it to my fiance. :D They also just pull the stem most of the time and let the air out. Technically, you can't get all the air out of the tire without pumping it out, and if you did that, the bead would break on the rim, and air would just leak in anyway. The tire would still have to retain some of the air it in, at least to atmospheric pressure. There is not a "possible" way that you could have 100% Nitrogen in the tire without taking some extreme procedures to assure it. Later, Jeff Link to comment Share on other sites More sharing options...
Member Contributer tbzep Posted November 10, 2006 Member Contributer Share Posted November 10, 2006 I'm using 78% nitrogen in my tires and it makes a huge difference. No more bent rims, no more crashes, no more ruined tires. The stuff is amazing! :goofy: Link to comment Share on other sites More sharing options...
Member Contributer FotoMoto Posted November 10, 2006 Member Contributer Share Posted November 10, 2006 Will this ? ever die? :goofy: :goofy: I was at the tire shop the other day (automotive) and there was an advertisement where they can fill your tires with nitrogen as opposed to compressed air. Thoughts? Easy answer: Did they charge extra for this? Link to comment Share on other sites More sharing options...
Trace Posted November 10, 2006 Share Posted November 10, 2006 Will this ? ever die? :goofy: :goofy: No, it won't. http://www.vfrdiscussion.com/forum/index.p...amp;hl=nitrogen http://www.vfrdiscussion.com/forum/index.p...amp;hl=nitrogen Hey, Doug....by the way, what kind of oil do you use? :P Link to comment Share on other sites More sharing options...
