Member Contributer Tejas Posted April 18, 2006 Member Contributer Share Posted April 18, 2006 I seem to remember a write-up that HS did that showed you how to add a manual fan switch to override it's normal operation. I've searched around and can't seem to find it. I would like to add a DPDT switch that would allow me to turn the fan on, off or run normally depending on switch position. Has anyone ever done this? Any tips or suggestions? Thanks! Link to comment Share on other sites More sharing options...
Member Contributer VFR FLYER Posted April 18, 2006 Member Contributer Share Posted April 18, 2006 I seem to remember a write-up that HS did that showed you how to add a manual fan switch to override it's normal operation.I've searched around and can't seem to find it. I would like to add a DPDT switch that would allow me to turn the fan on, off or run normally depending on switch position. Has anyone ever done this? Any tips or suggestions? Thanks! <{POST_SNAPBACK}> i would also be interested, and would like info on changing the thermocouple so it would come on automatically at 160 degrees.(hope this is not considered a hijack!) Link to comment Share on other sites More sharing options...
enzed_viffer Posted April 18, 2006 Share Posted April 18, 2006 I seem to remember a write-up that HS did that showed you how to add a manual fan switch to override it's normal operation.I've searched around and can't seem to find it. I would like to add a DPDT switch that would allow me to turn the fan on, off or run normally depending on switch position. Has anyone ever done this? Any tips or suggestions? Thanks! <{POST_SNAPBACK}> I believe the fan is switched on by the thermostat trigger for the fan shorting to ground. I was just going to say I'd go for just manually on or normal, but then I realised that when it stays on and you're moving the fan is fighting against airflow, so your idea is a goodun. Link to comment Share on other sites More sharing options...
Member Contributer Tejas Posted April 18, 2006 Author Member Contributer Share Posted April 18, 2006 I believe the fan is switched on by the thermostat trigger for the fan shorting to ground.I was just going to say I'd go for just manually on or normal, but then I realised that when it stays on and you're moving the fan is fighting against airflow, so your idea is a goodun. <{POST_SNAPBACK}> Yes, this is what I want to be able to avoid. Yesterday on my way home it was 98 degrees (What happened to springtime?) The fan kicked on at 221 just like normal and the temp got down to 207 when the traffic jam let up and it was back to normal highway speeds. The temp just missed getting low enough to turn the fan off (206) so it ran all the way home. By the time I got home the temp was 225 because the fans airflow was fighting against the normal air flow. Anyway...BUMP! Link to comment Share on other sites More sharing options...
Forum CEO HispanicSlammer Posted April 18, 2006 Forum CEO Share Posted April 18, 2006 UMM search not bump!~ Link to comment Share on other sites More sharing options...
Member Contributer Tejas Posted April 18, 2006 Author Member Contributer Share Posted April 18, 2006 UMM search not bump!~ <{POST_SNAPBACK}> HS I did search, I couldn't find it in the How to section or the electrical section. I did searches for fan, fan switch, cooling system and overheating. Maybe you could help me out here since I know you did a write-up on this. Hmmm? Link to comment Share on other sites More sharing options...
Member Contributer Tejas Posted April 18, 2006 Author Member Contributer Share Posted April 18, 2006 Finally! http://www.vfrdiscussion.com/forum/index.p...owtopic=386&hl= Can we get the pics restored? Link to comment Share on other sites More sharing options...
