Guest vfrrocky Posted March 29, 2006 Share Posted March 29, 2006 I'm looking for a fairly unique RAM mount solution for my Garmin GPS 376C for my '98 Superhawk. Due to the steering damper on that bike, I cannot use the common front gas tank mount that most VFR owners use. About the only space that's clear to use (believe I've tried everywhere) is the 19mm steering stem hole. I have a 19mm Stemstand for a different application, and it will not work for this particular application, so that's not an option. What I am looking for is a 19mm RAM expansion bolt. I found an example of it as #3 HERE. Further, but not exhaustive, searching revealed one store in Canada that sells the 19mm expansion plug. Shipping is kind of steep to the US, so I'm hoping someone here has a source to buy from in the US. Here's a link to the Canadian store: Scroll down to the 'Motorcycle Mounting' section, it is item #CA-GCEP19 CA-GCEP19 Rubber Expansion Plug Adapts RAM-B-252 and RAM-B-272 to many motorcycles with a 19mm steering spindle hole $19.95 CAD Can anyone help me to find this in the US? Thanks, Troy Link to comment Share on other sites More sharing options...
Guest Posted March 30, 2006 Share Posted March 30, 2006 Anyone? Link to comment Share on other sites More sharing options...
Guest maltnhops Posted April 7, 2006 Share Posted April 7, 2006 Can anyone help me to find this in the US?Thanks, Troy <{POST_SNAPBACK}> I'm looking for the exact same part. I found smaller ones at my local Ace Hardware. I think I'll stop in again tomorrow and ask if they can order a larger one. They were not very expensive. Link to comment Share on other sites More sharing options...
pseal Posted April 7, 2006 Share Posted April 7, 2006 That's my Ninja 250 at the top of the page you linked to. :-) You say you cannot use the gas tank mount; the bolt spread on the tank is the same as for the clutch lever/master cylinder on the VFR, and that's what I use; perhaps it's the same on your Superhawk? Payne border='0' alt='user posted image' /> Link to comment Share on other sites More sharing options...
Guest Posted April 7, 2006 Share Posted April 7, 2006 I ended up not needing that particular mount. I used a RAM mount that instead uses a strap clamp on the fork leg. It works extremely well. Troy Link to comment Share on other sites More sharing options...
Guest Posted April 11, 2006 Share Posted April 11, 2006 I'm not sure but it's worth the shot: look around on http://www.gpscity.com/rammounts.htm ... perhaps the very specific part you're looking for is available from them. Link to comment Share on other sites More sharing options...
Ahmed Posted April 17, 2015 Share Posted April 17, 2015 Short story! I found the expansion plug kit on this website for $8http://www.gpscheap.com/showproduct.aspx?productid=10172&affiliateid=10075&gclid=CjwKEAjw3sKpBRDJ7rDqzsyuhDASJACZAikiNJ9eqhr1X2Enp7Q2XQaC-SsH2vxlyVo9pXLExonsCxoCUzDw_wcB Long story! What I really wanted to do is to find a rubber expansion plug from a hardware store and have a DIY project. I am sure I could have created a plug that is going to be stronger. Then I was going to post that DIY steps here and everyone will be happy. However, after one day of searching I found a website that will send me the kit.. it's easier... Link to comment Share on other sites More sharing options...
Member Contributer huntinggunns Posted April 17, 2015 Member Contributer Share Posted April 17, 2015 Look at my steering stem mount thread. If that is what you need I can send you one. PM me if it is. Link to comment Share on other sites More sharing options...
