Member Contributer ron_al Posted March 29, 2006 Member Contributer Share Posted March 29, 2006 I have had my 94 VFR750 since May, 2002. It?s a great bike, but I wonder why I keep having headlight problems. I had a new regulator/rectifier installed by my local dealer in January, 2003. I lost the left high beam in October, 2003, replacing it with a Honda 45w/45w bulb. I lost the right high beam in January, 2005 (replacing it with a Sylvania Silverstar 55w/60w bulb from my local Autozone, with an adapter ring). This weekend (March, 2006), I get the bike out to go for a ride & find that I have lost BOTH high beams. However, both low beams work just fine. Both high beams worked just a couple of weeks prior to this, and the bike was left on a battery tender in the meantime. Has anyone heard of this happening? Or do you have any suggestions (aside from buying H4 bulbs in bulk)? Thanks! Ron Link to comment Share on other sites More sharing options...
Member Contributer BOBINOTTAWA Posted March 29, 2006 Member Contributer Share Posted March 29, 2006 Can't offer anything on the solution, but I can't say that I remember this being a mentioned problem on this forum, at least since I have been here. Link to comment Share on other sites More sharing options...
Member Contributer VFRGEEZER Posted March 29, 2006 Member Contributer Share Posted March 29, 2006 I used to run high beam all the time on my ST1100 and then my ST1300. They burnt out frequently. Running low beams I've not lost any bulbs so maybe the life of the high beam bulb is less do to the heat. VFR Geezer Link to comment Share on other sites More sharing options...
Member Contributer thereisnospoon Posted August 27, 2007 Member Contributer Share Posted August 27, 2007 Is anyone having specific problems with Silverstars (the designated motorcycle ones) burning out? I've had three go in about 3000 miles. The last one that burned I replaced with an el cheapo one from Oreilly auto... eight bucks vs. eighteen i thought was worth a thought. are there any other manufacturers of replacement bulbs this size besides Sylvania? I've never thought their stuff (I don't care if it's made in Germany) was particularly good but I can't find replacements anywhere other than OEM. Link to comment Share on other sites More sharing options...
FrankoQ Posted August 18, 2008 Share Posted August 18, 2008 I might have the same problem. Replaced the stock ones for silverstars. I have had them for about 1k miles. Now, both high beams are out. I mostly ride with high beams on. Low beams ok. I'll put the stock back on to make sure this is a bulb problem and not something else. If it's the bulbs, these silverstart are crap then. They should last a lot longer. They're $20 each. Link to comment Share on other sites More sharing options...
Guest Posted August 18, 2008 Share Posted August 18, 2008 Is anyone having specific problems with Silverstars (the designated motorcycle ones) burning out? I've had three go in about 3000 miles. Yes! Replaced both low beams with Silverstars, they went out in less than 1,000, miles. I put in standard replacements from some generic auto parts store when on a tour, they have lasted over 14,000 miles Link to comment Share on other sites More sharing options...
Guest Posted November 30, 2008 Share Posted November 30, 2008 Try Susquehanna Motorsports, http://www.rallylights.com/. Any H4 bulb will work. they sell Hella which in my opinion is miles ahead of Sylvania. Call and ask for information. They are the most informed lighting experts I know and not just lighting "salespeople". Link to comment Share on other sites More sharing options...
