klrtovfr Posted March 27, 2006 Share Posted March 27, 2006 I decided to hook my dual star grips up with a relay. They were working fine just hooked directly from switch to battery before. I got everything hooked up and turned the ignition on. Normally the fuel pump turns on for a few seconds and then shuts off. Now it just starts up and keeps going. I started it up and ran it for a minute and then it started bogging down like it was getting flooded, so I turned it off. I cant figure it out, I disconnected the relay but it still is acting up. Ive had a string of bad luck doing spring maintinance with the bike. Anyone else ever have this problem, and no what the culprit is? Link to comment Share on other sites More sharing options...
Member Contributer chris2992 Posted March 27, 2006 Member Contributer Share Posted March 27, 2006 1. Un hook the battery and let the computer reset and see if that helps. Sometimes the ECU needs to be reset, but I'd think that would trip the FI light. 2. Also completely unwire the relay, maybe you crossed a circuit or something, try to get back to the setup where the bike last worked. Link to comment Share on other sites More sharing options...
klrtovfr Posted March 28, 2006 Author Share Posted March 28, 2006 ok thanks unplugging the ground for the relay worked, im pretty sure I had it wired up properly. Ill have to try another ignition wire. Link to comment Share on other sites More sharing options...
Member Contributer chris2992 Posted March 28, 2006 Member Contributer Share Posted March 28, 2006 Use the license plate light circuit. Link to comment Share on other sites More sharing options...
