ChrisParaGR Posted May 9, 2023 Share Posted May 9, 2023 Hello everyone i got A problem with my VFR Sometimes when i try to turn on my moto it doesnt start and it needs some throttle to turn on, after this when she is on its going to stop working and the rpms go really low. Last time this thing happent i also had my check engine light on and my traction off!! The sound of the engine is like a cilynder doesnt work until it gets hot to start work normally! What the hell is going? Whenever this starts and try to go to my engineer she gets hot and then everything is fine like this never happent!! I found 1 more guy have this issue but still no solutions!! Anyone had something like this? Thanks in advance! PS: Before a week i replaced my spark plugs with new ones and my battery replaced before 2 years! 345493960_6722393101122666_532143895597092211_n.mp4 314625459_5565121790253640_8156736759657279301_n.mp4 344947819_6135431946564530_5154647494692013375_n.mp4 Link to comment Share on other sites More sharing options...
Member Contributer Grum Posted May 9, 2023 Member Contributer Share Posted May 9, 2023 You should have a look at what Fi Fault codes might be stored. Go through the process of reading any stored fault code, its mentioned in the Service Manual. Did this problem happen After replacing the spark plugs OR Before replacing the spark plugs? NOTE - It appears your bike (2016 model) may NOT display a Fault Code and the Fi Light will just remain ON. To read a fault code, you need to apply the Service Check Shorting link to the Data Link Connector! See the table attached for AFTER 2016 - PGM-Fi for OBD. Have a good read of section 4 of the Service Manual, take note of information for 2016 models. You can download the Service Manual from the forum. 2014 VFR800F/2015 VFR800X Service Manual https://www.vfrdiscussion.com/index.php?/files/file/271-2014-vfr800f2015-vfr800x-service-manual/ Link to comment Share on other sites More sharing options...
ChrisParaGR Posted May 10, 2023 Author Share Posted May 10, 2023 6 hours ago, Grum said: You should have a look at what Fi Fault codes might be stored. Go through the process of reading any stored fault code, its mentioned in the Service Manual. Did this problem happen After replacing the spark plugs OR Before replacing the spark plugs? NOTE - It appears your bike (2016 model) may NOT display a Fault Code and the Fi Light will just remain ON. To read a fault code, you need to apply the Service Check Shorting link to the Data Link Connector! See the table attached for AFTER 2016 - PGM-Fi for OBD. Have a good read of section 4 of the Service Manual, take note of information for 2016 models. You can download the Service Manual from the forum. 2014 VFR800F/2015 VFR800X Service Manual https://www.vfrdiscussion.com/index.php?/files/file/271-2014-vfr800f2015-vfr800x-service-manual/ It happent twice before i replace my spark plugs but it happent again before some days with the new ones!! Ill go to my Honda dealership to check if they can do something! Thank you!!! Link to comment Share on other sites More sharing options...
