Hello,
Does anyone have the torque settings for the VFR800-6? Preferably in .Pdf.
If not I specifically need, the front break nut to filling reservoir at the handles bars. Same for the clutch side. The nuts just below the filling reservoirs.
I'm installing heli bars and I need to angle the cables slightly forward so they require loosening. But I'm a stickler for doing things right so want to tighten them back up correctly.
Thanks,
Rory
There should be a workshop manual available in the Downloads section.
That will have every torque figure you should need.
