Member Contributer KevCarver Posted May 10, 2018 Member Contributer Share Posted May 10, 2018 2 hours ago, eleminop said: I almost bought the Rick's stator but wasn't sure if it was any good. (It's not) Link to comment Share on other sites More sharing options...
Auspanglish Posted May 10, 2018 Share Posted May 10, 2018 Now you need to do the fix on the common ground connector and other known factory wiring gremlins. Search on the forum for Eurythra and BYC and The drill... titles of three threads on the issues to fix and how. Otherwise you may well fry the new stator in no time. I've seen them go Kentucky Fried in 12 months or less Link to comment Share on other sites More sharing options...
Auspanglish Posted May 20, 2018 Share Posted May 20, 2018 OK. Trick is to wrap the connector in tape (any ahesive tape you can get back off easily) into a rounded elipsoid ballish shape, it´s the 90º edges which get caught up on things, that way it slides through easily without catching!! Link to comment Share on other sites More sharing options...
