Reddin Posted July 13, 2016 Share Posted July 13, 2016 On my 2002 VFR 800 I've recently removed the rear portion of my mufflers and pipe to the cat. This removed 26 Lbs of weight from the rear end. As a result of coarse how the bike handles has changed. I weigh 176lbs. Need to know how to remove some of the bounce from the suspension. Thanks Link to comment Share on other sites More sharing options...
Member Contributer Duc2V4 Posted July 13, 2016 Member Contributer Share Posted July 13, 2016 Apart from setting the sag and rebound damping (on the rear shock), not much you can do with the stock suspension. Where in Ca are you located? I'd say come on by and I'll help with getting the sag setup, it's much easier with two people. Link to comment Share on other sites More sharing options...
