Member Contributer lazyeye Posted May 23, 2016 Member Contributer Share Posted May 23, 2016 Has anyone done an evap-canister delete on an 8th gen? I'm considering doing it to make oil changes less painful. Link to comment Share on other sites More sharing options...
Rsparky Posted May 24, 2016 Share Posted May 24, 2016 Search reveals results... I just did it. The big diameter hose going up, with the rubber tube needs plugged. Or take off the right fairing and remove the solenoid, and plug it there. Or go under the airbox, and plug it right at the throttle bodies. Depends how lazy you are. I did mine under the fairing. The small diameter hose that comes from the left, remove the additional length, and put it with the other drain hoses. The rest, just rip out. Link to comment Share on other sites More sharing options...
